Results 1 to 10 of 14
Thread: front strut bolt
    UK
    Question front strut bolt
    Do you need some special tool to take the top strut nut off? I tried a 21mm offset spanner but the neck of the spanner seems to hit the top strut plate.
    yep, special tool needed so you can turn the nut while holding the centre shaft still with an insert bit...
    Proper damper tool set required normally.
    Remember never to undo the top nut without having the springs firmly held in the spring compressors..very very dangerous otherwise..
    UK
    Thanks, wheres the best place to get one from?
    Snapon or other tool agent...have you tried EBAY for a search..
    UK
    Ok, i'll have a look around
    Regular Member chrisschild's Avatar
    May 2006
    Wiltshire
    Vehicle : Vectra Hatchback
    Engine : 2.2 DTi
    beat me too it! ^^^ lol, as said, make sure springs are secure!!
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    Not ideal but if you have an old spanner you can grind the back of the ring so that it fits in.
    UK
    I had thought about doing that but I would have a problem getting the new nut torqued back up. I've had a look around but still unable to find a tool todo the job. Someone mentioned a slotted socket, so Im going to have a look to see if I can find one, im pretty sure its 21mm or 13/16th.
    If anyone wants to share where they have got there tool from I would be most gratefull.
    UK
    Well I have ordered a set of Vortex sockets from Amazon, only cost £33 and has 13 sockets, one of which is a 21mm. Im not quite sure how to torque it back up to 20nm though, the Vortex set has an adapter to turn the socket into a 1/4" or 3/8" drive, but how do you hold the center spindle when a normal torque wrench is on it.
    What i need is one of these but a 21mm http://www.s2-audi.co.uk/tech_articl...do_top_nut.jpg
    Maybe VX sell a tool for doing these. Anyway cant wait to get the Bilsteins on
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    I know it's not quite correct but don't worry about torquing the nut up,if you can do a wheel bolt up tight the nut will be ok.
  1. Front strut help
    By jodiexii in forum Suspension, Wheels & Brakes
    Last Post: 9th July 2012, 09:23
  2. Front suspension strut
    By mungo1985 in forum Suspension, Wheels & Brakes
    Last Post: 24th April 2012, 23:10
  3. Strut Top Bolt
    By 0uT1aW in forum Vectra C / Signum Car Chat
    Last Post: 1st February 2011, 21:17
  4. used front strut bearings
    By paul.sessions in forum Parts for sale
    Last Post: 14th January 2011, 18:40
  5. Front strut brace
    By vectraturbo in forum Handling & Braking
    Last Post: 4th July 2007, 20:26
how to take front strut bolt off vectra
