Results 1 to 10 of 24
Thread: rear brake binding
    Regular Member corman's Avatar
    Mar 2007
    hexham
    Default rear brake binding
    back brake passenger side has just started to bind on, noticed the smell last night then again tonight and the wheel was warm to touch
    any ideas what has gone wrong? and more to the point.... whats the cure?
    i'll have a look on wed when i'm off work but it would be nice to have some ideas before i go poking about
    does anyone have any diagrams of the rear brake setup?
    could be sticking pads on the caliper carriers..or a sticky piston..if you haven't got a rewind tool for the vectra-c, then nows the time to get one..
    strip the brakes down, wind the calipers back in, and clean the pad rests before reassembling it with a smear of copper grease where the pads touch the caliper and the carrier..
    Mar 2007
    hexham
    cheers Mark, i reckoned it would be a strip job, is this a common problem or am i just unlucky?
    not very common..just thought as well..check the pins are clean and free when you take then out to get the calipers off..and smear them lighty in grease when you put them back in..
    Jan 2006
    Skynet HQ EMEC#5
    Also worth a check to see if the protective boot is split.
    I think that was the main reason mine siezed up, letting water & crap in.
    West
    Quote Originally Posted by Ian T View Post
    Just had same prob, it was so bad had to replace caliper
    Mar 2007
    hexham
    havent had a look yet (hopefully tomorrow)
    what did it cost for the replacement?
    This is a design flaw, from cost-cutting
    Rather than have separate brake pads and brake shoes it is now an all-in-one
    Binding brakes a common fault as a result
    I had this in my previous Mondeo and it resulted in two replacement handbrake cables, followed by two sets of rear pads and discs
    Mar 2007
    hexham
    just a quick update
    the caliper didnt have any of the boot left, just the ring left on the caliper, the disc must have been so hot its cracked both the brake pads........
    so i've ordered an exchange caliper (better be safe and sure its not going to stick straight away again) and since its in bits may aswell pop some new discs on at the same time as the pads
    any tips to watch out for while putting it all back together?
    Nov 2005
    scotland
    Just make sure that you slide the spring clip on the back of the pads so that it sits in the groove in the piston. Pump out the brake pedal so that the pads are against the discs before applying the handbrake, so that the auto adjuster inside the caliper works properly.
  1. handbrake binding rear brakes
    By krisby in forum Suspension, Wheels & Brakes
    Last Post: 28th November 2011, 16:36
  2. brakes binding
    By Al 22 dti in forum Suspension, Wheels & Brakes
    Last Post: 14th May 2011, 21:43
  3. Rear brakes binding! Help
    By tonyblade in forum Vectra C / Signum Car Chat
    Last Post: 6th October 2010, 14:00
  4. N/S Rear Caliper Binding
    By si_hoss in forum Suspension, Wheels & Brakes
    Last Post: 8th March 2010, 10:42
  5. Rear Brake Binding - 2006 Signum Elite
    By spj555 in forum Suspension, Wheels & Brakes
    Last Post: 25th September 2008, 13:06
vectra c handbrake binding
