Thread: Engine oil - you get what you pay for (or do you?)
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Default Engine oil - you get what you pay for (or do you?)
    I know there's been a lot of talk about engine oil, the cost, the viscosity etc, etc,. and generally you get what you pay for.
    I'll gladly go along along with this theory if somebody can explain different oils, similar specification but very different prices.
    I've taken 5W-40 synthetic as an example as I use this in my 3.2 V6:
    ACEA A3, B3, B4, API SM/CF Multipart 5W-40 £12.99 for 5lt
    ACEA A3,B3,C3, API SM/CF, Amsoil 5W-40 £43.99 for 5lt
    ACEA A3/B3, A3/B4, API SM/SL/SJ/CF Mobil 5W-40 Synt S £29.99 for 4lt
    Very similar oils, almost identical spec but would you use Amsoil rather than Multipart just because it costs more?
    This difference becomes more obscure if you look at say 0W-30 oils from Multipart, Mobil, Fuchs, Castrol and Amsoil (there are others obviously). Same specs, very different prices.
    I just play it safe, and use OEM VX oils.....and the 5w30 fully synth is only £26 for 5 litres....
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Have a read of this information
    Or heed Marks advise above. Much easier to simply stick the OE oil verified oil in, as it's not too expensive anyway.
    Regular Member jamesr's Avatar
    Lancashire
    £26 for 5 litres?
    I paid £43 last time??
    Regular Member WeDesign's Avatar
    Jun 2006
    Vectra-C.com
    Engine : CDTi 150
    Year : 55
    Can you change your oil too often, what is the minimum miles (if there is any)?
    Belfast
    I found Halford's own brand fully synthetic was actualy pretty good - used their PD-spec stuff in my old DTi, lasted much better than even Castrol Edge and Mobil 1.
    Jul 2006
    Mexico
    I dont think there is a minimum...you can change it every day....the key is to change it often, before the oil looses its properties...which takes several miles
    member of the smoke patrol 230bhp+
    £26 mark im getting that for £16 + vat and it 0w30
    Jul 2006
    Mexico
    I always use Mobil1...oil of the champions
    Jun 2006
    Vectra-C.com
    Engine : CDTi 150
    Year : 55
    Quote Originally Posted by chrisgettings View Post
    do they do that for the 1.9 CDTi engine?
  1. 1.9 cdti Z19DT estate engine juddering plus white smoke coming from engine bay
    By danedragger in forum Vectra C / Signum Troubleshooting
    Last Post: 25th January 2013, 17:44
  2. Can I replace a Z19DT engine with a Z19DTH engine, fairly easily?
    By Krusty3380 in forum Engine & Drivetrain
    Last Post: 13th August 2012, 15:24
  3. Replies: 35
    Last Post: 5th May 2012, 15:32
  4. Yellow engine light staying on & engine getting hot.
    By Phil Campbell in forum Engine & Drivetrain
    Last Post: 20th March 2010, 08:56
  5. Replies: 3
    Last Post: 28th April 2009, 19:49
