Results 1 to 10 of 17
Thread: Has Anyone Actually been Visually warned that a DPF Regen is Taking place & Completed
    Regular Member DeanF's Avatar
    Nov 2007
    Staffordshire
    Default Has Anyone Actually been Visually warned that a DPF Regen is Taking place & Completed
    How many drivers of Diesel Particulate fitted cars have actually been warned & seen the Visual warning (Glow Plug Light) on the dash illuminate & then extinguish once complete. ??.
    As per Handbook " Flashing, Dpf requires cleaning, As soon as traffic permits, Increase speed to more than 25 Mph for a brief period, The indicator extinguishes once complete"
    Now i have had the latest Regen software under the recall & i have never seen the glow plug light illuminate/flash, But it has done a regen, Noted by the heat & smell of the exhaust, Smoke & 0.9 Mpg economy at Tickover.
    Mine just seems to illuminate the Car with the spanner through it at startup & then goes out once running
    Another forum users input on the latest update software
    Regeneration is the process which produces a high temperature in the Diesel Partical Filter to effectively “burn off” the soot particles. Achievement of the required DPF temperatures requires the engine to be operating at sufficient speed and load conditions to trigger and sustain the process. Generally the vehicle needs to be driven at a speed of 25 to 30 mph or more for a period of approximately 15 minutes to complete regeneration. Providing these driving conditions are achieved on a regular basis, DPF regeneration will be triggered automatically with no further intervention required. Some types of use, e.g. short urban journeys, do not allow complete automatic regeneration to take place.
    In this instance the driver should ensure that the vehicle is driven regularly within the required regeneration parameters for a short period.
    Vauxhall / Opel (1.9 Diesel)
    An optimised soot loading model for the DPF has been developed to initiate automatic DPF regeneration at a lower level of soot loading of the DPF.
    This reduces the likelihood of complete DPF clogging.
    Additionally, the impact of an aborted regeneration (driver switches off engine before regeneration completion) is reduced.
    Should the lower soot loading threshold be reached, the driver will now receive warning that a regeneration is required viaflashing of the instrument glow plug light. This will enable the driver to initiate a regeneration by driving to the required parameters when road and traffic conditions permit.
    Failure to achieve an automatic regeneration will lead to clogging of the DPF. If this occurs, the engine warning light will illuminate and the engine electronics will switch to the emergency running programme.
    The DPF will require a manual regeneration which can only be initiated by a Vauxhall Authorised Repairer."
    Thoroughly confused
    Dean
    Feb 2006
    Guttedsville
    Nope. not once in 6 months and not far off 13000 miles.
    Mind you, mine's not a town car, so it might not be needing a regen quite so often.
    Regular Member John35's Avatar
    Jun 2007
    in a white box
    Never seen it either.......
    never in the 2 1/2 yrs we had the cdti, thou you could tell when it was doing it...but you have to have tech2 plugged in..
    Regular Member Karl's Avatar
    Sunderland
    not once (and 12K)
    Nov 2007
    Staffordshire
    My car does do short journeys each day, 8 miles to work & 8 back Etc, But more miles at the weekend.
    This Car & Spanner light may well be a red herring, Although there are no fault codes stored, It does say Emmissons Control..
    Tonight the Car & spanner illuminated but still no regen like before.
    Perhaps the Ecu does need to be read by a vauxhall Specific reader to get the full picture ! But im concerned that i will be paying for a code read only to be told, " Nothing Stored Sir"
    Im also having the Car remapped tomorrow & did not want to have to go back to Vauxhall & for them to over write the map
    Dean
    Regular Member Gaz the Cab's Avatar
    Nov 2007
    Chester
    Not at all, 50k in a year, but I dont know what they did at the service the other day but it is a different car.........it now goes how I thought it should .
    Regular Member ukanalyst's Avatar
    Jul 2006
    Cheshire
    Never seen an indication in 21,000 miles except for as you say, smell & increased fuel consumption
    Dave
    Nov 2007
    Staffordshire
    Spoke to a different chap today at Vauxhall & apparently the visual display that a regen is taking place has been removed. To many people were going to the dealerships complaining of an error/fault, Light displaying Etc.
    Personally, I would rather be aware of a Regen taking place & stopping Etc, It helps with preventitive maintenance, i.e keeping driving whilst it is in progress to enable it to complete properly !!!
    A backward step in my book
    Dean
    Full Member Big Sig's Avatar
    But with the amount of people not reading the manual, I bet they had thousands asking what the light was, I think they made the right decision, although I understand your point.
  1. SRI Vectra: Read and be warned!!!
    By Stringlabel in forum Troubleshooting
    Last Post: 9th February 2009, 21:58
  2. V6 cdti Alternator [be warned]
    By davef in forum Engine & Drivetrain
    Last Post: 10th March 2008, 20:52
  3. Failed MOT - Be Warned!
    Last Post: 1st December 2007, 21:36
  4. You Have Been Warned............!!!!
    By Drinky in forum Comedy & Humour
    Last Post: 8th October 2005, 13:47
