I own a Vectra CDti (150) 55 plate, it has done 33,600 miles, it had been serviced at 18,780 miles on 6th Dec 06, (before i owned the car) when is the next service due and would it be an intrim or major?
If the one at 18k was its only service, then it will be a major one with brake fluid change recommended (mark )
..correcto..
would that be at 40,000 miles?
maximum...i wouldn't leave it the 20,000 they state..far too long between services....i strongly recommend over servicing the car..
Yes I would say so without knowing if you have a dpf or not.
wats a dpf?
Diesel Particle Filter....do a search on the forum for more info....
it's a cheap way of cleaning up the diesels smokey habit..
I knew that was comming
Its a diesel particulate filter, only really fitted to estates, autos and signums. If it has - I don't know how you tell for sure - its 10 k servicing I believe.
Your profile says you have an auto so you will have a DPF
