Thread: Smoking 1.9CDTi 150
    New Member shuggy73's Avatar
    Jan 2008
    Glasgow (south side)
    Default Smoking 1.9CDTi 150
    I have a '54 plate 1.9CDTi 150. Driving today there was some blue/black smoke from the exhaust when accelerating and an acrid/exhaust smell when stoped.
    Noticed it on the way to over to the witch in laws and the smell when the car was stoped. There has recently been a smell from the vents on cold start up but have read that this may be from a cold diesel cat. Bit of a smell again on start, but could not check the smoke as it was dark.
    Thanks in advance fro any help/advice.
    blue/black smoke is either oil burning ( very bad) or overfuelling ( not so bad)..
    you need to check in daylight and see if it still does it...
    Regular Member DeanF's Avatar
    Nov 2007
    Staffordshire
    Quote Originally Posted by shuggy73 View Post
    Does it have the DPF ? Diesel particulate Filter..
    When these are Regenerating the car does smoke & stink..
    Dean
    Jan 2008
    Thanks for the speedy response.
    Have had it out in the daylight today, ran it stationary no sign of smoke, took it out and warmed it up on the motorway and drove quite hard, again no sign of smoke. Where is the DPF and is the smoke the only indication of the re-gen cycle?
    Nov 2007
    Staffordshire
    The Dpf is infront of ( But joined to) The centre Cat.
    Some info here with regards to identifying.
    http://forum.vectra-c.com/showthread.php?t=37046
    I had the latest regeneration software put on mine & the dealership could not tell me if any Visual warning now illuminated prior & during the Regen process, So Who knows, Previously it used to illuminate & flash the Glow plug Light, But it didn't this time !!
    Dean
  1. Smoking engine? 1.9cdti
    By mr-s in forum Vectra C / Signum Troubleshooting
    Last Post: 18th April 2012, 10:05
  2. Thats it, i've given up smoking
    By Ademusic in forum The 'Off Topic' room
    Last Post: 22nd May 2010, 12:47
  3. smoking
    By andy76 in forum Vectra C / Signum Troubleshooting
    Last Post: 15th May 2010, 19:21
  4. Smoking
    By James Stewart in forum The 'Off Topic' room
    Last Post: 5th March 2009, 21:26
  5. Im smoking!!!!!!!
    By David in forum Engine & Drivetrain
    Last Post: 25th March 2006, 12:31
