Results 1 to 10 of 18
Thread: swirl city
    Regular Member dreadaz's Avatar
    Jan 2008
    bognor regis
    Eek swirl city
    Hi there, quite new to the detailing scene, a few weeks ago brought a cheapish polisher it was a dry day today so gave the car a wash and dry, and began to give her a polish with the polisher,
    i thought i'd done a good job but it started getting dark so i brought out the flood light i've got swirls everywhere!!!!
    so what products can i use with my polisher to remove these?
    also don't know if i'm doing something wrong but i put quite a bit of polish on the sponge head of the polisher started at a slow speed got a bit faster then within about 30-40 seconds the polish is more or less gone and the polisher starts bouncing around the panal is this just cos its a new pad and i have not used enough polish???
    or i'm not using enough pressure??
    any help would be much appreciated! thanks.
    Your polisher deffo shouldn't be bouncing matey.
    What polishes are you using? Also what's the make of polisher you have?
    Jan 2008
    bognor regis
    its one i got from my mate at the bodyshop (its prob a finishing polish)
    do i need something like megs 83 like an abrasive polish?
    Jan 2008
    bognor regis
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...MEWA:IT&ih=003
    this is the polisher i brought just a cheapy!
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 110000
    You need to prime the pads first mate with some QD, this stops the polish disappearing into the pad and Keeps things cool.
    Yep, megs83 would do the trick, if the polish dissapeared that quick sounds like you had it too fast maybe, are you using a polishing pad, or just the wooly bonnet ?
    Jan 2008
    bognor regis
    its like a thick foam/spongey pad??
    Vehicle : SRi
    Mileage : 110000
    But is it a cutting pad, polishing pad or a finishing pad? It should say on the pad top.
    Jan 2008
    bognor regis
    Don't know just says m14 on it
    its very dence when you squash it it takes a while to go back to its original shape?
    Vehicle : SRi
    Mileage : 110000
    THB I would buy a set of megs pads and backing plate, then you know where your at. Also try running at a lower speed like 1500 rpm and spritz the pad with qd, this should help stop the hopping. Its a big step going straight onto a rotary without using a pc first (i know ive done just that) but just do your research and work slowly. The weight of the machine should be enough so dont go pressing on or you could burn the paint.
  1. Chelski v man city
    By bigmac in forum The 'Off Topic' room
    Last Post: 2nd March 2010, 22:02
  2. Swirl city no more
    By bobssignum in forum Non Vectra C/Signum Album
    Last Post: 6th September 2009, 21:48
  3. Football, Man City
    By styles997 in forum The 'Off Topic' room
    Last Post: 13th April 2009, 12:54
  4. A Sunday Spent Cleaning - NO MORE SWIRL CITY!!!
    By Vaux-Man-G in forum Quick Photo Album
    Last Post: 30th March 2009, 18:20
  5. man city
    By neverlandandy in forum The 'Off Topic' room
    Last Post: 26th February 2009, 22:34
