Thread: Which springs
    Regular Member John35's Avatar
    Jun 2007
    in a white box
    Default Which springs
    Piggy bank has broken so I'm buying some springs. Reading a few threads on suspension, some of you are not happy with the drop of the front of the car. So with a front axle weight of 1090kg and rear 1100kg.
    Should it be the first or second springs.
    10-65-011-01-22 Front up to 1060kg rear up to 1215kg
    10-65-011-02-22 Front 1061 to 1130kg rear up to 1215kg
    thoughts please.......
    Regular Member BigMan's Avatar
    Jun 2007
    Pretending to be unmarked Police in my T5...
    Right, I have been thinking this for a while now...
    If you bought the lesser weight springs for the higher rated weight car, what would the effect's be??
    Would it lower it further, and if so, are there any other side effects?
    Sorry for the thread hijack John.
    However, The right ones are the second ones John...
    2nd one's...first ones are marginally underrated and may experience coilbinding as the car will sag very hard on them..
    Jun 2007
    in a white box
    Quote Originally Posted by BigMan View Post
    No hijack, that was the point I was trying to make. Will the front be higher than the back because there is only a 30kg difference with the first ones and a difference of 40kg with second set.
    So its going to be the 2nd set......
    thanks for the replies
    the fronts always sit a little higher John, the drop is even and the front already rides high..
    spoons had some springs for sale that would bring it down evenly..
    Here, there and every where!
    Springs of the wrong weight spec will probably invalidate the insurance (if the unthinkable did happen) if they looked hard enough m8.
    Jun 2007
    in a white box
    if they fit, then I would be very interested. The axle weights for these springs are unknown at the moment.
    Jun 2007
    John, The VXR performance centre do the springs Spoons had on his old Vectra Diesel, they give it something like 45mm drop at the front, and 35mm at the back. Penfold had his done a few weeks back, Didint cost the earth either...
    Quote Originally Posted by John35 View Post
    they fitted his 150 hatch, so they won't be a million miles away from yours..
    Jun 2007
    in a white box
    E-mail sent to VXR performance ( I may as well dream) for their springs.
    Will probably go for Eibach springs in the end unless............
  1. replacing standard springs with Sri springs
    By mon in forum Handling & Braking
    Last Post: 31st December 2012, 22:03
  2. springs? coilovers? shocks/springs?
    By Dan. in forum Vectra C / Signum Car Chat
    Last Post: 4th March 2011, 19:01
  3. Replies: 5
    Last Post: 21st July 2010, 16:14
  4. vxr springs
    By supersione in forum Handling & Braking
    Last Post: 18th July 2010, 16:21
  5. 2.0T SRI Springs
    By Baz07 in forum Parts for sale
    Last Post: 9th July 2008, 13:28
