Thread: Front fog lights, how to get into them??
    Regular Member v6diesel's Avatar
    Southampton
    Default Front fog lights, how to get into them??
    Hi all,
    The front fogs are all misted up on my 06 SRI and I have had a poke around but cant find any easy way into them. Can anyone let me know the best way to get into the back of these please.....
    used to be a screwcap underneath them..
    Here, there and every where!
    Common fault m8, trip to the dealers and get them to change them. They should clear after about 10 mins of use though and that's what the dealers will probably tell you to do though
    Regular Member simac's Avatar
    Wirral
    I had the usual n/s light misted up. I removed the cap from underneath and about a pint of water fell out !! I drilled a tiny drain hole in the centre of the cap and put it back, it's been fine since
    Southampton
    Cheers chaps, I have been underneath the car and all I can see is undertray
    Do I have to remove all of that just to get at the lamps?
    yep, remove the undertray..thou you might just be able to bend down the front corners if you remove those fixings in that area..
  1. front fog lights
    By steve19cdti in forum Electrical & ICE (including SatNav)
    Last Post: 30th June 2011, 20:57
  2. Led H3 front fog lights
    By bobssignum in forum Styling
    Last Post: 8th May 2011, 17:15
  3. Front fog lights
    By xf8u39 in forum Electrical & ICE (including SatNav)
    Last Post: 14th January 2011, 13:37
  4. Front fog lights.
    By VectraGezza2010 in forum Vectra C / Signum Car Chat
    Last Post: 10th January 2010, 21:44
  5. front fog lights
    By dcdevlin in forum Vectra C / Signum Car Chat
    Last Post: 5th November 2009, 18:21
