Thread: V Hot Disc situation after Rear Pad chnage !
    Regular Member DeanF's Avatar
    Nov 2007
    Staffordshire
    Default V Hot Disc situation after Rear Pad chnage !
    Had my rear pads changed whilst the car was having new rear top control arms (Struggling to get anything done myself with these dark nights & P!ss wet weekends)
    When i got back home the rears were binding terribly & red hot, Spit on the finger just sizzled !!
    So today during a dry hour,, Jacked up the rears & they were binding, Split the caliper & wound back the pistons & re-assembled, Worked the handbrake sevreal times to get it to work..
    Went for a drive & came back, The discs were moderatly warm but no sizzle ( I had not done as many miles as previously though) Jacked them up & they spun freely..
    Question ?
    Would it of been possible for the garage to of wound the psitons out to far in the beginning ? making the handbrake already partially applied ?
    I never checked when i had them split if it is possible to wind the piston out (Anti Clockwise) also ??
    Dean
    Regular Member BigMan's Avatar
    Jun 2007
    Pretending to be unmarked Police in my T5...
    Genuine Pads, or Pattern Pads??
    it is, but it sounds more like the pads where binding on the pad carrier..did they wirebrush and copper grease the pad rests when they did the job?..
    they can't wind them too far out, but they can fail to wind them too far in, but then you'd still have the problem now..they have to be wound back, they won't go back while driving..
    sounds like it needed your intervention, and while you had it apart you cured it..
    member of the smoke patrol 230bhp+
    if its not been winded back all the way i could see that the pads would bind like mad
    Nov 2007
    Staffordshire
    Quote Originally Posted by BigMan View Post
    Pattern i would say ..
    Dean
    Nov 2007
    Staffordshire
    Yes, all was copper slipped up & i checked that the pads moved freely in the carriers, Hopefully as you say, Now cured.
    Cheers all
    Dean
  1. rear disc removal
    By andy_richmond in forum Vectra C / Signum Car Chat
    Last Post: 12th December 2012, 20:19
  2. rear disc heating up
    By coooky in forum Suspension, Wheels & Brakes
    Last Post: 29th March 2012, 20:24
  3. rear disc and pad replacement
    By mitch in forum Suspension, Wheels & Brakes
    Last Post: 5th June 2010, 19:43
  4. rear disc and pad set ????????
    By mark the hat in forum Vectra C / Signum Car Chat
    Last Post: 31st December 2008, 19:31
  5. Rear disc & pad set
    By yorkshireborn in forum Vectra C / Signum Car Chat
    Last Post: 13th September 2008, 22:18
