Thread: WARNING to all changing bulbs
    Regular Member Craig1985's Avatar
    harwich essex
    Exclamation WARNING to all changing bulbs
    WARNING.. i un bolted and un pluged control box next to the battery to make extra room to change bulb, BUT when conecting them together again i bent a small pin in a connector block( causing fogs not to work) also the engine managment light to come on. spoke to vx the said recommened bent pin so checked and luckly straighened it and now works they said to clear engine man light i had to deadlock car then unlock and start... all works, i was luck.............could have been costly?
    so be warned my friends..........
    [Ex]Admin Duncan's Avatar
    Sounds like the main ECU harness plug that you disconnected!!! Gotta be careful with that one.
    harwich essex
    whoops
    Yep, deffo one to disconnect the battery before disconnecting. Short a terminal and it could be fried ECU!
    Quote Originally Posted by vectra1.9cdti View Post
    You don't need to do that to change the bulb do you?
    On the 3.0 V6 CDTI all you need to do is unclip the screenwash holder, remove it, then lift the battery box cover out of the way
    Access is poor, but not impossible!
    Regular Member Ian's Avatar
    York
    I think its easier to take off the front bumper and remove the headlight, especially on a facelift!!
    Cirencester
    Quote Originally Posted by Ian View Post
    nah, i got massive fat hands and even i can get my hands in to change bulbs, main and dip, easy enough
  1. Replies: 13
    Last Post: 23rd March 2013, 23:10
  2. changing headlight bulbs
    By triple595 in forum Vectra C / Signum Car Chat
    Last Post: 14th November 2011, 22:27
  3. Changing Headlight Bulbs
    By wittsy` in forum Vectra C / Signum Troubleshooting
    Last Post: 4th February 2011, 21:49
  4. Changing NSF bulbs
    By ScottR in forum Electrical & ICE (including SatNav)
    Last Post: 19th July 2010, 22:26
  5. Changing bulbs.....
    By T4M in forum Vectra C / Signum Car Chat
    Last Post: 28th January 2008, 14:30
