Thread: CD70 Sat Nav Not working
    Jan 2008
    Bolton
    Default CD70 Sat Nav Not working
    Got a Cd Stuck in Eject button wouldnt do anything. The disk wont even spin.
    Button still works coz it switches the whole unit on if pressed.
    Removed the Cd and reset the Carrige inside but there doesnt seem to be any power to the Cd drive.
    All the other options in the Menus work like the Audio and BC work. there is the arrow in the middle showing the sat nav but nothing happens when I try to enter it. The big Navi button doesnt do anything either.
    Is there a fuse inside the unit or anything else that control the cd drive.?
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    has your car still got warranty, if so go and see the dealer's imo
    Midlands Mod Shop - NFFC.
    Oct 2006
    Wellingborough
    his profile says 2004 so no warranty
    You can probably get a dealer to perform a reset on th unit which -may- help, but beyond that it's going to be tricky.
    Jan 2008
    Bolton
    In a way its a good job its not still under warrinty as soon as I took the first screw out it would be invalid.
    I took it apart again today and wound on the laser eye, the system should do a test of its self when switched on.
    The upper cd drive did this but the Nav cd drive didnt.
    It must be something to do with the power supply getting to the nav unit.
    Will do some phoning around tomoz. See if any car audio shops can help.
    Thanks for your replys guys.
    Oct 2006
    Wellingborough
    If you're handy with a multimeter and soldering iron i am sure you can track the fault. as you say if the laser is not doing any alignment check on startup it sounds like no power.
    There are a few comapnies who refurb headunits/other vehicle electronics, i am sure they can help you out if you get stuck.
    member of the smoke patrol 230bhp+
    book the headunit in for repair at a good car hifi shop then get a price befor you go ahead with the repair
  1. CD70 satnav not working
    By davidj387 in forum Electrical & ICE (including SatNav)
    Last Post: 13th December 2012, 23:44
  2. Help !! CD70 working but Navi has died ??
    By Dre in forum Electrical & ICE (including SatNav)
    Last Post: 14th April 2011, 17:43
  3. TMC not working on CD70 Navi
    By Abernus in forum Electrical & ICE (including SatNav)
    Last Post: 9th January 2010, 11:09
  4. CD70 nav...gps not working??
    By Dippy-Vx-line Red in forum Electrical & ICE (including SatNav)
    Last Post: 27th July 2009, 17:21
cd70 navi not working
cd70 navi navi button wont eject
navi opel cd 70 unresponsive buttons
sat nav not working in vauxhall vectra
vectra sri satnav not working
cd 70 navi not working
vauxhall corsa sat nav stopped working
cd70 navi buttons not working
cd70 navi disc tray not working
vauxhall CD 70 NAVI stopped working
cd70 buttons not working
vauxhall vectra sat nav not working
cd70 navigation not working
sat nav disc stuck cd 70 navi
vauxhall vectra cd70 navi not working
opel cd 70 cd stuck
vectra c nav disk stuck
vauxhall corsa sat nav not wiring
vectra navi disc not loading
vauxhall sat nav not working
