Results 1 to 10 of 10
Thread: what size torx bit for rear seatbelt?
    Oct 2007
    Mid Wales
    Default what size torx bit for rear seatbelt?
    I think i might need to remove the rear seat belt mount to take out the interior trim to get to the rear quarter window.
    What size torx bit will i need for the bolt at top of the seat belt?
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    i think they are a t50 m8
    Regular Member EURO G's Avatar
    Dec 2007
    n ireland
    not 100% sure but i think its a 45
    Dec 2007
    n ireland
    there you go im wrong
    just went and checked and they are 100% a torx50 fella
    Oct 2007
    Mid Wales
    Thanks Glynn, really appreciate you going to check for me!
    Is that size easy to get hold of at DIY shops do you know? The set i've got are only small
    Quote Originally Posted by spartan80 View Post
    halfords will sell them or any motor factors m8 hope you get it sorted now you now the size. i think they will come as a set aswell as separate
    Oct 2007
    Mid Wales
    so just to confirm before i go to halfords tomorow, the rear seat belt bolt at the top (under a black plastic cover which you can push in to adjust the height of the seat belt up and down) is definately size T50?
    100% YES i have one in my tool box and went to the car and checked for you
    Oct 2007
    Mid Wales
    Thanks glynn, REALLY appreciate it!
    Looks like i'll be busy in the morning. I'm planning on taking out the trim in the boot which holds the rear parcel shelf. Trying to get to the quarter windows to check if they're leaking - got some moisture in the boot and inside the C pillars
  1. Rear top seatbelt runner Torx size?
    By BigWilko in forum Bodywork & Interior
    Last Post: 21st May 2012, 19:25
  2. Torx bit size
    By st2malo in forum Engine & Drivetrain
    Last Post: 15th May 2011, 13:11
  3. Torx Bolt Size - Rear Suspension Dampers
    By spoons in forum Vectra C / Signum Car Chat
    Last Post: 1st November 2010, 16:51
  4. torx size ????
    By anr_n_vec in forum Engine & Drivetrain
    Last Post: 23rd September 2010, 21:35
  5. TORX bolt size ?
    By FIL 4822 in forum Vectra C / Signum Car Chat
    Last Post: 12th May 2008, 15:19
torx seat insignia
