Thread: Dropping Revometer
    Jan 2008
    Telford
    Default Dropping Revometer
    Hi there,
    First post on the forums.
    I'm looking into buying a Vectra C 52 Reg, the 2.0 TDi Model.
    The current owner has told me that whilst driving the revometer drops to 0 and sticks. He then said that turning off and turning back on the car will rectify it.
    What could be the problem and am I looking at an arm and a leg to fix?
    Also, Whats the Life expectancy on the 2.0 TDi Engine? Its on 106k Miles.
    Are there any tell signs of faults to look out for.
    Thanks,
    Craig
    Cirencester
    did vauxhall even make a TDi?
    thought they did a Di, DTi and CDTi?
    Jan 2008
    Telford
    As far as I was aware the DTi, Running off info I wrote down from the seller.
    Regular Member Karl's Avatar
    Sunderland
    sounds like a loose wire somewhere tbh. Maybe only a loose cable to the binacle. The 2ltr dti is a touch slow tbh. It has some known issues (best doing a search fro them on here)
    If possible I would search for a 1.9 CDTi if you can, they are alot better to drive, and (if you get a 150bhp one) both quicker and better on fuel.
    The 120 bhp version is about the same on fuel as the 2ltr but is quicker.
    going back to your fault.. it sounds like either a wiring issue, or the infamous CIM module is causing the problem..if it's the CIM, thats £400....
    DTi's , if they've been well serviced every 10,000, will see 150,000+ quite easily but they do have a few issues a said before.
  1. Av MPG dropping badly!!!
    By Governor in forum Diesel Engine related
    Last Post: 19th January 2012, 15:58
  2. Revs Dropping
    By mikeq in forum Troubleshooting
    Last Post: 30th January 2011, 18:52
  3. dials dropping
    By craigleeds in forum Electrical & ICE (including SatNav)
    Last Post: 3rd January 2011, 14:12
  4. i think im dropping to a vec B
    By carlsondavid33 in forum Vectra C / Signum Car Chat
    Last Post: 26th October 2010, 15:10
  5. Dropping the c.....
    By bobby-tupper in forum Quick Photo Album
    Last Post: 17th February 2009, 20:48
