Thread: Lexus is 220d
    Regular Member ion's Avatar
    walsall
    Default Lexus is 220d
    Hi Everyone,
    As I said, I've had a Lexus is 220 today, here are my thoughts:-
    Looks wise its good, not fantastic but it looks quite sporty & classy, although the body is a bit "tall". I don't know whether it's me though but they ALL look the same! (I didn't bother with pics due to this)
    Inside is fantastic, with beautiful instruments, trim & upholstery, you really feel it's something special when you get in.
    The start sequence (button operated) is incredible, the lights come on in a pattern, the needles on the dials light up & swoop right across, then back, then it fires up. Amazing!
    Ride wise, again it's superb, very quiet, it rides similar to our cls at work, which is brilliant. I could not get it to feel unsteady at all, & it soaks the bumps up. It has the perfect balance of stiffness & "give" so it doesn't crash & thump.
    The engine is very smooth & quieter than the vec at tick over, about the same under load & maybe slightly noisier if you’re giving it some. It pulls well & feels relaxed even if you hammer it.
    If you cruise around making chilled out to moderate pace, it is the best car I've been in for the cash.
    So it's excellent then.......
    BUT
    It has the following flaws that rule the car out for me:-
    Firstly, it is way, way, way too thirsty. I averaged 26mpg!!!!!. Holy cr@p, that wasn't hammering all the time either, I promise. I did a run up the m6 to stafford & back using cruise & during that time it was only averaging 40mpg at about 70-75!!! If you push it more it's even worse!
    Secondly, the gears ratios are wierd:-
    1st is very short indeed, 2nd is much longer, 3rd is short again, then 4th is about right, 5th is almost the same as 6th in a vec, while 6th is virtually useless, you cannot use it below 85mph, if you do it vibrates the rear view mirror so everything blurrs (I'm not joking, I swear!!).
    It seems like 5th is ideal up to about 65, then 6th is way too high so you're in th middle, how dumb is that!!!
    Thirdly, it doesn't pull like the vec 1.9, although it's a manual, it feels like an auto, it seems to pause, then go, but not with the surge of the vec. It feels like it's holding back. Just when the revs build & you think it's really going to go, that's it, time to change, & with the wierd ratios, it's not a "seamless" change. It's like you boot it & the car says "what? you must be kidding, I'll go on my terms, & I'm not pulling too hard either, so bl00dy wait!"
    Fourthly, there's something missing, I don't know what, it just lacks something, it feels a bit dull & soulless after a while, even a bit tiring.
    So that's it, the lexus is not for me.
    It's a stunning machine, but it's big weakness is the engine/gearbox, which to me are a large influence on what I drive. If they sort this it would beat the opposition hands down.
    I was really excited about driving this as well, I wanted to like it, but it just didn't do it.
    Back to the drawing board!
    I'm still borrowing my mom's vec b then for now lol
    Nicking Ya Dinner.
    If you have to leave VX, get an A4 TDi and map it if you feel you need to.
    Mileage : 000
    26 mpg................... Ian does that mean a 3.2 Elite is out of the question then??
    Regular Member dave45040's Avatar
    llandudno
    Am I right in thinking that, if you have the in-built media centre in the car (i.e. the factory fitted one) it is the ONLY Sat Nav system that you can't set whilst you are moving (i.e. you have to either pre-set it from home or stop in a layby to set)?
  1. The Lexus
    By Rebellion8878 in forum Non Vectra C/Signum Album
    Last Post: 10th February 2013, 13:39
  2. Lexus LFA
    By CDTi-SRi-Matt in forum General Chat
    Last Post: 23rd October 2009, 12:16
  3. I Wants Me A Lexus
    By VauxVeteran in forum Vectra C / Signum Car Chat
    Last Post: 17th January 2007, 14:51
  4. Lexus ?
    By cpt slow in forum Styling
    Last Post: 4th July 2005, 19:33
