Thread: Rear suspension
    Jan 2008
    Builth Wells
    Default Rear suspension
    Does the suspension on all vectra's look like the bottom is further out than the top (i.e not at 90 degrees) - The other days a man stopped at traffic lights and told me somthing was wrong. The dealer says it is ok? and other Vectra's i have seen seam to be the same - I am not so sure, somtimes I look at it and get seriously worried as it looks like it may collapse some day.
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    as ed taylor said in your last thread could be the rear trailing arm bushes worn
    Alot of them do depends on the weight in the boot and the age of the suspension if it's a bit tired it will kick in at the top best bet is to replace the springs and dampers then get the rear camber pulled in should sort it out ....it will also sort out your tyre wear problem as in your other thread !!!!
    Regular Member simac's Avatar
    Wirral
    Mine has always looked like its got a bit of negative camber on the rear, since I bought when it was a year old. Besides the rubbish shocks everything else seems fine wear and tear wise.
    Jan 2008
    Builth Wells
    Hi. It was recalled soon after we had it to replace the bushes. It has been back in about half a dozen times since about the banging but they could never cure it. Someone reversed into the side of me last month and I have just had it back were they rebult the suspension (replaced as knock hit wheel) so I will see if the problem sorts itself out now.
  1. rear suspension
    By leedavis1971 in forum Vectra C / Signum Car Chat
    Last Post: 17th October 2012, 21:33
  2. Rear arm suspension
    By Sambor in forum Suspension, Wheels & Brakes
    Last Post: 30th May 2010, 10:37
  3. rear Suspension
    By Tom Tom in forum Vectra C / Signum Car Chat
    Last Post: 16th July 2009, 00:11
  4. rear suspension
    By DennisTheMenace in forum Suspension, Wheels & Brakes
    Last Post: 24th November 2008, 18:33
  5. Rear Suspension
    By Landroverdave in forum Suspension, Wheels & Brakes
    Last Post: 4th September 2007, 10:12
