Thread: Temperature
    Jan 2008
    Builth Wells
    Default Temperature
    Hi. My temperature gauge never seems to rise. I took the car to the main dealer and they said it was reading correctly but it was always very low, now it is not moving at all? I have owned the car since 2002 and this has been a problem only in the last year.
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    sounds like a temp switch or the thermostate is on its way out
    If your heater is still working ok I.E getting hot then i suspect a faulty temp sender if the heater takes a long long time to get luke warm then it will point to the thermostat !!!!
    ^^^^^ what he said..
    Jan 2008
    Builth Wells
    Hi. Thanks for your advice. To be honest I dont think the heater is as efficient as it was when I first had it. I did tell the dealer that I thought it was the thermostat but they said that the computer said it was fine. Maybe I need to take it to another dealer, the problem is that were I live there are not many about.
    Feb 2007
    Dundee
    I have a similar problem!
    Can anyone help by advising where the temperature sender and thermostat are located!
    Thanks!
    Jan 2008
    Builth Wells
    My gauge does not even twitch anymore yet the heater is ok. The garage said the guage was measuring the same as the sender when they had it in to check some time back (when the guage was just intermittant) - So I wonder if it is the gauge itself which I suppose could be expensive to replace.
  1. Temperature help!!
    By Lex82 in forum Electrical & ICE (including SatNav)
    Last Post: 21st July 2012, 15:14
  2. Temperature changes
    By skene in forum Vectra C / Signum Car Chat
    Last Post: 15th July 2012, 19:58
  3. Temperature
    By Wolfie01 in forum Engine & Drivetrain
    Last Post: 13th February 2012, 10:34
  4. No Outside Temperature.
    By lammy1961 in forum Insignia car chat
    Last Post: 30th January 2012, 15:58
  5. max outside air temperature...
    By bobby-tupper in forum Vectra C / Signum Car Chat
    Last Post: 6th June 2009, 11:03
