Thread: Brake warning light
    Jan 2008
    Builth Wells
    Default Brake warning light
    Hi. When I had my pads replaced last the warning light did not turn off. When I next had the car in for a service at the main dealer they ordered me a new sensor but when I went to collect they said it was not the sensor but rather in the wiring and it would be a huge job to fix? I have lived with it since but having just found this forum I thought it may be good to see if anyone else has had the same issue.
    I think for the sake of a tenner it's got to be worth a try i have only ever known the sensor being the reason why the light comes on !!!!
    Regular Member BigMan's Avatar
    Jun 2007
    Pretending to be unmarked Police in my T5...
    As Drinky said, it would be unlikely it would be anything else. I have had a brake pad wire pack up before the pads were even worn. They can and will pack up at their own free will.
    Nov 2005
    scotland
    The wire in the harness sometimes breaks about 9 inches from the plug (on the body side of the plug). Peel back the conveluted tubing and check the wires. It could be that.
    yep, if you can find the break, a repair is better than a replacement loom..
    Jan 2008
    Builth Wells
    Hi. That would match up to what the dealer said, although they made it sound like a big job.
    they will replace the entire loom...rather than repair it..
    as your car is out of warranty, take it to an independant garage who will repair it at far less cost..
  1. Brake Warning light and display error message , BUT BRAKE LIGHTS ARE WORKING FINE
    By JACKALG1 in forum Electrical & ICE (including SatNav)
    Last Post: 24th May 2013, 18:56
  2. 3rd brake light warning
    By madvenny83 in forum Vectra C / Signum Car Chat
    Last Post: 22nd November 2010, 07:26
  3. Brake warning light
    By dandsi in forum Suspension, Wheels & Brakes
    Last Post: 9th January 2010, 16:32
  4. Spanner light & 3rd brake light warning?
    By simp_2.2sri in forum Electrical & ICE (including SatNav)
    Last Post: 5th December 2008, 17:32
  5. Brake warning light
    By scar_vectra in forum Suspension, Wheels & Brakes
    Last Post: 23rd June 2007, 12:48
