Thread: Rear tyre wear
    Jan 2008
    Builth Wells
    Default Rear tyre wear
    Hi. I have had my Vectra since 2003 and since owning it the rear tyres have always worn on the inside really quickly. When I initially found it the dealer replaced the two tyres for free and sent the car off to be four wheel aligned. Since then it is has always been the same. Is this just mine or is it a common issue?
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    sounds like your camber is out on the rear, have you tried a tyre and exhaust center with a computer tracking machine
    Mileage : 55000
    Or the bush,s are worn.
    Regular Member BigMan's Avatar
    Jun 2007
    Pretending to be unmarked Police in my T5...
    If its running at standard height, then i would nt have thought the camber's would be out, More likely as Ed says, there is a bush or two that is worn.
    Jan 2008
    Builth Wells
    Hi. It has been like it since new, and even after a recall to change the bushes. They have always worn and it was even sent off for full 4 wheel alignment. National Tyres told me it was common on Vectra's but I was worried when I looked through the forums and found no other mentions.
    4 wheel alignment won't always include the rear camber, which i would get checked.. excess negative camber does cause uneven rear tyre wear..
  1. uneven tyre wear on rear
    By croado in forum Suspension, Wheels & Brakes
    Last Post: 14th July 2011, 19:12
  2. Rear tyre wear
    By Geoff644NI in forum Suspension, Wheels & Brakes
    Last Post: 29th March 2011, 22:00
  3. Which rear part causes tyre wear?
    By stuartbat in forum Vectra C / Signum Car Chat
    Last Post: 2nd November 2009, 22:19
  4. Rear Tyre Wear
    By johnmac in forum Suspension, Wheels & Brakes
    Last Post: 28th June 2008, 22:20
  5. Rear tyre wear Vecta 03
    By gordonc in forum Suspension, Wheels & Brakes
    Last Post: 24th June 2007, 16:52
