Thread: central locking "bug"
    Jan 2008
    shropshire
    Default central locking "bug"
    If I use the interior button to lock the doors (while in the car) and then manually lift the drivers door lock to get out, using the remote to lock the doors does not lock the driver door (as you would expect)
    and you have to use the remote to unlock, then lock the doors.
    is this a bug in the central locking system?
    tony
    2007 1.8 SRi Nav
    nope, totally normal..
    Here, there and every where!
    Lifting the driver's door button is not unlocking the central locking, only the drivers door. That's why you then have to unlock with the remote then lock with it
    Jan 2008
    shropshire
    so it was designed to do this!
    I had done this 3 or 4 times before I realised, so I left my car unlocked while I left it.
    guess I will have to turn on the auto lock/unlock function
    Full Member Big Sig's Avatar
    Or you could use the same button to unlock them that your using to lock them????
    Jan 2008
    shropshire
    I could but I am so used to using the door button (as on my old vectra) I have difficulty breaking the habbit (I only lock them if going into "risky" areas)
    Oct 2006
    Wellingborough
    Auto lock is easiest thing to do, only thing is it unlocks when removing the key, so annoying if a passenger wants to get out and you want to keep the ignition on/engine running.
    Jan 2008
    shropshire
    That would prompt me to use the switch then.
  1. "Winter" Wheels ? Are 19" Snowies best for the "Summer" ?
    By Woody in forum Vectra C / Signum Car Chat
    Last Post: 5th October 2012, 18:43
  2. central locking /"door open" Help!
    By tommoturbo in forum Electrical & ICE (including SatNav)
    Last Post: 5th October 2009, 07:22
  3. worried!!!! have you ever used "corsa centre" or "supernovas"
    By vectra_c_wannabe in forum The 'Off Topic' room
    Last Post: 20th May 2009, 15:21
  4. "Goodbye" blue sky "Hello" grey !
    By FIL 4822 in forum General Chat
    Last Post: 8th November 2008, 15:43
  5. "Goodbye" grey sky, "hello" blue !
    Last Post: 24th October 2008, 12:34
