Results 1 to 10 of 11
Thread: 1.9 cdti Unknown part
    Regular Member bgm46's Avatar
    South Queensferry
    Default 1.9 cdti Unknown part
    Hi all,
    The part is located at the front of the engine bay to the left of the battery cover.
    It says VAC on it. I am assuming it is a pressure switch.
    The problem is i have a small air leak from it, does anyone know if this will
    cause any probs?
    Cheers,
    Brian
    got a picture of it?..
    South Queensferry
    Give me five, will take one
    South Queensferry
    Fisrt time uploading an image so hopefully works!!
    http://i264.photobucket.com/albums/ii178/bgm46/Part.jpg
    Full Member Big Sig's Avatar
    That white bit with the hoses?
    South Queensferry
    Yep
    Nicking Ya Dinner.
    Where does the hose go to?
    member of the smoke patrol 230bhp+
    it goes to the wastegate
    it keeps the wastegate closed if you get a leak you may find that your turbos starts to over boost
    you really need to fix it
    South Queensferry
    http://i264.photobucket.com/albums/i...46/Part2-1.jpg
    Hose marked with Green goes under the car, other can be seen going into the the silver pipe on top of engine
    South Queensferry
    thanks a lot for the info, will do a temp repair and get a replacement ordered up.
  1. 2 Part Clutch Kit 1.9 cdti
    By platty in forum Engine & Drivetrain
    Last Post: 26th February 2012, 20:48
  2. unknown valve
    By iwtand in forum Engine & Drivetrain
    Last Post: 30th January 2012, 19:38
  3. unknown fault
    By alexgrfc in forum Engine & Drivetrain
    Last Post: 14th August 2009, 21:30
  4. Unknown fault????
    By bigpaw35 in forum Vectra C / Signum Troubleshooting
    Last Post: 2nd August 2009, 19:35
  5. cdti engine part??
    By the-wizard in forum Vectra C / Signum Car Chat
    Last Post: 23rd December 2007, 19:40
