Results 1 to 10 of 13
Thread: 2.2 timing chain
    SCOTLAND
    Default 2.2 timing chain
    i have noticed recently that when i am driving at higher speeds (70-80mph) my engine is starting to sound a bit different. hard to describe as i am not very mechanical but a bit tappetty or rattly.
    Its a non direct 2.2 petrol and has done 53000 miles (04 plate) and i wondered if it may be the timing chain and if i should get it changed soon?
    any ideas
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    i could be the tensioner as i think it also feed oil to the chain. i think they get changed at about 100.000 miles correct me if im wrong
    or when they start to rattle..Had it serviced recently G?...try some fresh oil and see if that helps it, but it may well need the chains changing..
    Full Member Big Sig's Avatar
    Seems a bit early at 53k though doesn't it? Would that engine of had the recall on the oil jets for the chain lube system?
    jets where changed size from 2001 on, so being 04 it would have the bigger jets..
    chains can wear at what ever rate they like, so 50K isn't really that unusual..
    Ok it was just a thought. Although, I still think that 50k if pretty bad when they are supposed to be for life. Belts last longer then that - sometimes
    SCOTLAND
    not been serviced properly for a wee while mark so that may be all it needs but i think i'll book it in for a chain change to be on the safe side. Safer to go to a main dealer do you think for that? My girlfriends brothers quite mechanically minded and fixes his own car so would be cheaper just the thought of the chain going would be naff
    dealer job really G..they are DIY'able, but you really nned someone who's done one before and knows all the pitfalls...
    SCOTLAND
    cheers mark, i'll prepare by bank account for a big dent!!!
    around a £400 dent G....
  1. Timing chain
    By dave_scarborough in forum Engine & Drivetrain
    Last Post: 27th April 2012, 22:30
  2. timing chain
    By barneyp06 in forum Vectra C / Signum Car Chat
    Last Post: 28th July 2010, 11:04
  3. timing chain mod
    By cavysri16v in forum Engine & Drivetrain
    Last Post: 21st February 2010, 10:46
  4. timing chain
    By gsp1 in forum Engine & Drivetrain
    Last Post: 25th May 2009, 23:13
  5. Timing chain??
    By wazza007 in forum Engine & Drivetrain
    Last Post: 28th September 2008, 10:02
