Thread: SRI lip spoiler
    Regular Member mickeyc's Avatar
    Over there between the land and the sky!
    Default SRI lip spoiler
    Hey guys,
    Finally settled in after the move and found the sri lip spoiler ninja sold me but the adhesive tape had got all damp so I had to strip it off. Is the best course of action to simply replace the tape (and if so what sort and where can I get it?), do I need to go through the rigmerole of buying the VX kit and drilling the bootlid or is their some other way?
    Any thoughts welcome
    cambs
    hi
    i just stuck mine with a good quality double sided tape
    about £10 for a 5 mtr roll. go for the best
    well worth the money as you dont want the lip spoiler to fall off
    and be carefull when placing the spoiler on the hatch.
    when the tape is on dont pull the tape cover off
    just peel a bit off on the end so you can get a hold of it
    place and line it on the hatch so it is sitting correct
    hold in place then pull the tape cover off and press firmly down untill all is stuck.
    take your time getting it in the right place before removing tape cover or you will have to start again.
    Is this the sort of thing you mean? Anything else on that site look more suitable?
    cambs
    hi
    this looks like the stuff i used
    it was this size and thickness and looks like the same packaging as
    the one i used and a lot cheaper
    you could give it a try
    http://cgi.ebay.co.uk/DOUBLE-SIDED-M...QQcmdZViewItem
    it's what would be used in a bodyshop, and well up to the job..
    Thanks mhvcbv and Mark as ever. Bought and paid for the tape, all I need to do now is make a mess of putting it on
    Obviously it needs doing in the dry but does it need time to set too?
    cambs
    Quote Originally Posted by mickeyc View Post
    also make sure the place where the lip is going is very clean
    i used lighter fluid to clean mine or a good window cleaner will do
  1. Vauxhall World DTM spoiler and boot spoiler
    By suj786 in forum Vectra C / Signum Car Chat
    Last Post: 12th October 2005, 23:45
