Results 1 to 10 of 17
Thread: 2007 Vectra 2.2 Auto - Rear Fog Light
    Regular Member Gordon B's Avatar
    Jan 2008
    Washington
    Default 2007 Vectra 2.2 Auto - Rear Fog Light
    I was amazed to find that me Vectra Elite only shows one rear fog light even though the n/s light has wiring and a bulb. Is there anyway of getting the n/s light to work?.
    Also can anyone tell me if my car should have a drivers seat belt warning, either a light or a sound, if you don't put the seat belt on with the engine running?
    More questions to follow.
    Thanks,
    Gordon.
    Jul 2006
    Mexico
    I guess it should have a belt warning mate...both sign on the dials and sound...at least preface has them.
    BTW...all vecs have only one side working fog in orther for the guys in the back to tell the difference between fog light and brake light....hope that makes sense LOL
    11 Post(s)
    Only one fog light required, as per EU (or somethingorother) ruling. The bulb on the nearside can be used as a spare bulb anywhere in the rear light clusters as they're all 21 watt bulbs. Some people have bridged a wire across from one fog light to the other, but as you've got bulb failure warning on the Elite, you'll get false error messages all the time. Just stick to the one fog light if I were you. It's not as if you need them every day of the week and unless you get some real pea soupers where you live, then you're not going to need the two of them.
    Seat belt warning is an optional extra, and not standard fitment. Never yet seen a Vectra with the warning fitted. Should be pretty obvious if you've got the belt on or not though to be honest.
    Jul 2006
    ^^^ what he said - particularly the bit about the seat belt warning. Anyone stupid enough to drive without one will be more than happy to ignore any warning device that's fitted. You don't 'forget' to wear your setatbelt....
    Regular Member sig63's Avatar
    Belgium
    Vehicle : Opel Insignia
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    Quote Originally Posted by parapaul View Post
    ... Anyone stupid enough to drive without one will be more than happy to ignore any warning device that's fitted...
    ... I don't think so: you can ignore the flashing red light in the dash but the noise is unbearable ! I think this is a good thing; over here both warnings are standard for the front seats (and it is 2 points in te EuroNCAP ratings)
    Larkhall
    All the new Astras have the seatbelt flash/beeping but i haven't seen a Veccy with it.
    11 Post(s)
    Occasionally I have to drive an Astra or Focus. Both have the seat belt warnings. Trouble is the journey I do is stop / start around a perimeter fence. Not practical to keep putting on and taking off the seat belts every 100 yrds. The audible warning is annoying, so to overcome that I wrap the seatbelts around the rear of the seats and then clip them into place. I know there's a way to shut the Ford warning up, but as it's a pool car, other people will question why it doesn't beep at you anymore if you forget to put on the seatbelts.
    Jan 2008
    STOKE ON TRENT
    I rang my local vauxhall dealer and asked about the one fog light.
    i was told thatif the brake light fails on the N/S the fog then works as a brake light ?
    Jan 2008
    Washington
    Thanks Guys, this is my first post on this forum and it's good to know there are members out there willing to pass on there knowledge to others.
    All the above make sense, and yes I always wear my seat belt, it comes as second nature, like closing the door and starting the engine. My point was, if the car had this facility then it should work, and Big Dave is right, the rear fogs are only used now and again, I didn't know that it would double as a n/s brake light if the proper one failed.
    My previous Vectra was a T reg CDX, that seemed to have more on it than this new Elite, things like Traction Control, door lights and the display told you about which bulb has failed, low water (both coolant and screen wash) low oil, low brake pad etc etc...anyone know how many of these things my new Vectra will have?
    Thanks again guys, sorry to go on so long.
    Regards,
    Gordon.
    Regular Member simac's Avatar
    Wirral
    The seat belt warning was standard on the earlier Vecs but has been removed from the later ones, this is what i've been lead to believe anyway.
  1. For Sale: Vauxhall Vectra SRi V6CDTI Nav 2007 Auto
    By sb1uk in forum Cars for sale
    Last Post: 27th August 2012, 21:44
  2. number plate light on vectra c 2007
    By N3ERN in forum Vectra C / Signum Troubleshooting
    Last Post: 8th February 2011, 22:09
  3. rear light fault 2007 estate
    By ramsgate in forum Electrical & ICE (including SatNav)
    Last Post: 25th April 2010, 19:01
  4. Vectra C 2007 Rear Lights - Pair for Sale
    By Phil MC in forum Parts for sale
    Last Post: 7th April 2009, 13:41
  5. auto dipping rear view mirror light
    By greeningr in forum Vectra C / Signum Car Chat
    Last Post: 10th March 2006, 20:38
does a 2.2 vectra elite have 2 rear fogs
