Thread: Replacing CDR2005 with CD70
    Norway, Fredrikstad
    Default Replacing CDR2005 with CD70
    I've done a bit of reading on the forums now, and from what I understand, the problem with this switch is that the controlbuttons on the steeringwheel won't work.. Is that it or is there some other issue?
    I don't like those stupid buttons anyway, so if that's the only problem, well it isn't a problem at all.. =)
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Quote Originally Posted by Lemric View Post
    If you search on here there is a thread for this and it saya that if you have a car pre 54 - i think then it is not compatible with any stero system after that.
    Something to do with CANBUS - What ever that does - possible the car's personality mines is stubborn.
    Gotta ask is you stereo c**p? Skips CD's? Mines does but when I found out the information above - well i've gotta live with it.
    Gazza4
    Norway, Fredrikstad
    Since I live in Norway, I really don't know what a 54-plate is.. =) My car is a 2004 model tho, and therfore have the "half canbus" But as I understand all that the canbus does is translate the signals from the steeringwheel?
    I've done lots of reading and searching on here, great spot for info.. =)
    So if the canbus is the problem I hope that it would be possible to make the switch and just do without the buttons.. (That I don't use anyway)
    Norway, Fredrikstad
    Just bought the car about one month ago, but so far the cdr2005 works just fine.. Plays cd's with no problems.. =) But i would like to have the satnav system..
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    I don't know too much about the system myself but if all it does is translate button signals then there should be no issues.
    My car is a latev 2004 and is affected by this canbus problem too.
    No doubt someone will pop along with the answer.
    Gazza4
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Again may be difficult with sat nav, according to threads on here if it is not factory fitted you are outta luck.
    Hope i'm wrong tho!!
    Gazza4
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    i belive their is more involved as you will need the wiring loom behind the dash which is complete for the whole car
    Oct 2006
    Wellingborough
    Yep, the CD70 will be looking for speed and steering inputs over canbus, as well as ignition status and lighting status.
    Replacing your small orange screen with a standalone satnav unit will be cheaper and easier.
    Norway, Fredrikstad
    Well, that's stupid.. =p Why do they have to make it so complicated!? Well, I'll go for a aftermarket 2din unit instead then.. Don't know what to do with that ugly orange screen tough.. Have to fins some creative use for the space.. =)
    someone on the site had put a touch screen sat nav in one of the air vents and it looked very flash indeed
  1. Replacing CD70 Navi
    By Astra_Alex in forum Electrical & ICE (including SatNav)
    Last Post: 14th October 2012, 23:28
  2. Aux in cdr2005
    By Ken072 in forum Electrical & ICE (including SatNav)
    Last Post: 21st July 2011, 15:00
  3. CDR2005 to CD70 Nav
    By tomtaylor15 in forum Electrical & ICE (including SatNav)
    Last Post: 5th May 2010, 00:01
  4. Replacing CDR2005 on '04 Vectra w/single DIN radio-what do I need?
    By mikethemechanic in forum Electrical & ICE (including SatNav)
    Last Post: 17th November 2009, 17:30
  5. Cdr2005
    By glenboy in forum Parts for sale
    Last Post: 22nd August 2009, 20:11
