Results 1 to 3 of 3
Thread: Weird???
    Regular Member mc_orion's Avatar
    Aug 2007
    Worcester...and most motorways!
    Default Weird???
    The other week i had my on board computer show up that i needed to check the right hand brake light, i did ad it was dead, so i went to the local motor factors an got another bulb an swapped them over.
    Bout 3 days ago i had it come up again then go off, every so often the flash bulb comes up on the dash as well, but as soon as i pres ok, the bulb goes out after about 30 secs, after ive pressed the ok button...
    Anyone shed any "light" on this strange weirdness??
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Quote Originally Posted by mc_orion View Post
    Get it once per month but I have read on here that there are two brake bulbs per rear light unit and when one fails the other kicks in. If you look at the rear of the car whils someone presses the brake or you put something on the pedal you will see that both lights do not sit at the same level - actually i need to try this!!
    Cheers for reminding me!!
    Gazza4
    It could be something as simple as a loose connection on the new bulb matey.
    Try changing all the brake light bulbs as well, because if the canbus detects one bulb is drawing less current than the others it may think there's a fault. If all the bulbs are new then they'll all be drawing the same current. Just a thought.
  1. Weird
    By spoons in forum The 'Off Topic' room
    Last Post: 17th August 2012, 17:49
  2. Weird cut out!
    By Chip in forum Engine & Drivetrain
    Last Post: 4th June 2012, 18:35
  3. Weird.....
    By Das in forum Electrical & ICE (including SatNav)
    Last Post: 13th August 2011, 23:32
  4. Bit Of A Weird One This
    By Tam80 in forum Vectra C / Signum Car Chat
    Last Post: 18th February 2011, 15:52
  5. em..... am i weird...
    By Vectralicker in forum Vectra C / Signum Car Chat
    Last Post: 10th June 2009, 11:35
