Results 1 to 10 of 11
Thread: Handbrake Failure on Post 06 Siggy's and Veccy's
    Regular Member Signum_CDTI's Avatar
    May 2007
    Somewhere and Nowhere....
    Default Handbrake Failure on Post 06 Siggy's and Veccy's
    It seems that after Watchdog this week (or was it last?!?!) that Vx are finally admitting that there might be a problem with the handbrakes on these motors.
    Handbrake has released itself on me, causing car to park itself into a wall, scuffing paintwork etc etc.
    Apparently, a stronger spring is getting fitted to locking mechanism (or so I'm told). So why has it taken Vx so long to acknowledge the problem??
    Also, in work the other week, one of our 'job' Veccy VXR's took itself for a drive accross the yard, smacking into a van and ripping the side door off - so Vx - there is a problem, and it's not driver error! Ca't get better than a Class 1 Police driver!
    Hope they get their thumbs out and get it sorted!
    Admin plasma's Avatar
    On the Forum
    256 Post(s)
    Engine : 150
    Mileage : 74000
    Being a class 1 police driver you should know to leave it in gear! cause all of us including you dont know how to operate their handbrake correctly!!
    Thx Vx for the lovely marshmellow handbrake!
    Regular Member ianjofriel's Avatar
    Jan 2008
    Glasgow
    i checked my handbrake today after all the comments recently, it's quite high, but guess that's because it probably needs new rear pads and needs adjusting, but it's definitely secure, gave it a good thump ( as hard as i could without damaging anything including me ) and it didn't budge... mine's an 07 plate ?
    Doesn't anyone RTFM anymore?
    Advice when parking:
    Always apply handbrake firmly. On slopes apply the handbrake as firmly as
    possible.
    With manual transmission, select first gear or reverse, for automatic transmission or CVTronic, place selector lever in P.
    Jul 2006
    The point is (without bringing up the whole debate again) that the handbrake, by law, must be capable of holding the car stationary. If it's not capable of that, whether it be by design fault or anything else, then it needs to be rectified.
    Leaving the car in gear is just a precaution - that handbrake should be sufficient.
    Quote Originally Posted by parapaul View Post
    Hmmm, over 1 ton of metal being prevented from rolling away by a rachet mechanism and some bowden cable. Leaving the car in gear as well should be compulsory, not a precaution.
    May 2007
    I totally agree with this - you can't rely on the gear's when doing a hill start on a 1:4 hill can you?? Handbrake is sh*te at the best of times. Get it sorted Vx
    Quote Originally Posted by andrew the bobby View Post
    But you are in the car when trying to do a hill start. So if the handbrake does fail you are there to put your foot on the brake pedal. If the car were parked on a 1:4 hill (unatended) at least if left in gear, it's not going to run away if the handbrake should fail.
    btw, you can rely on the gears when doing a hill start - it's called clutch control
    Regular Member Craig1985's Avatar
    harwich essex
    changing subject, but as your a copper yor'll know answer? do police have to show you video evidence if i ask for it? was traffic police who stoppedf me? i asked and he said it only records n unable to play back? bull sh....i....t? hope u can answer? cheers
    Regular Member pauls898's Avatar
    Malvern
    I was horified at VX suggestion on BBC Watchdog of applying the hand brake while NOT pressing in the button!!! My driving instructor from years ago would have gone mad if I applied the hand brake without first pressing the button in
  1. MOT Failure - Offside Handbrake
    By sriturbo in forum Suspension, Wheels & Brakes
    Last Post: 13th October 2009, 15:53
  2. handbrake failure!!!
    By ilaing in forum Vectra C / Signum Car Chat
    Last Post: 10th May 2008, 17:44
  3. Handbrake Failure
    By Ben H in forum Vectra C / Signum Car Chat
    Last Post: 16th October 2007, 16:49
  4. Handbrake failure - a known fault?
    By Ewormaharg in forum Suspension, Wheels & Brakes
    Last Post: 26th June 2007, 23:44
  5. Handbrake failure
    By Sparkyvxr in forum Vectra C / Signum Car Chat
    Last Post: 16th April 2006, 20:18
