Page 1 of 4 123 ... LastLast
Results 1 to 10 of 39
Thread: 314mm upgrade help needed right now!!
    Regular Member Vid's Avatar
    May 2007
    In the inventing shed...
    Default 314mm upgrade help needed right now!!
    Hi guys,
    just gone to fit the bigger brakes, I have the capilers, discs and pads, but it looks like the carrier won't fit over the disc, it looks too small.
    Can someone confirm that you can definately do it with the existing carriers, my car is a 2002 2.2 sri.
    Here, there and every where!
    Done!
    What kit did you get m8, the LMF kit i had was perfect
    May 2007
    Quote Originally Posted by Caterman View Post
    Done!
    The kit from vauxhall, per the thread on fitting the upgraded brakes...
    search for 314mm upgrade, one guy said he had ordered the carriers, someone else said that they weren't needed, and that was for a 1.8?
    Carriers should not be needed m8, the caliper should bolt straight on. Have Vx given you the 314mm calipers though
    May 2007
    Yes, with the part numbers I got from that thread. One left, one right!
    May 2007
    There just seems no way that the carrier is going to have the bigger discs fit under them. Did you get the carriers when you bought the kit off LMF?
    Nope, as i said, i fitted the 314 LMF kit onto my old 1.9 CDTi SRi with 285mm standards and no carriers were needed m8
    May 2007
    What year was the car mate, just out of interest?
    May 2007
    2005 on a '54 plate. Try PM'ing Mark (GSi3.2) and ask his advice m8. He know's Vx's inside out and will know the answer for sure.
  1. upgrade the 314mm to vxr set up or upgrade the rears?????
    By rob warrington in forum Handling & Braking
    Last Post: 24th September 2012, 09:26
  2. 314mm Upgrade
    By AdeyCorp in forum Handling & Braking
    Last Post: 28th June 2009, 08:10
  3. 314mm brake upgrade
    By steve1975l in forum Suspension, Wheels & Brakes
    Last Post: 30th June 2008, 21:12
  4. Help please. 314mm upgrade
    By Vec-trance in forum Suspension, Wheels & Brakes
    Last Post: 13th June 2008, 02:08
  5. 314mm upgrade...
    By danBoy in forum Handling & Braking
    Last Post: 27th December 2007, 20:33
