Thread: Fitting Mud Flaps...Flappy
    Regular Member Dwabo's Avatar
    Carterton, Oxfordshire
    Default Fitting Mud Flaps...Flappy
    might tackle the mud flaps tomorrow as the car is full of cr &p already in a matter of days...
    just a quick question... reckon i need to take the wheels off to do em?..
    anyone with the flappy ones ..how did you do em?.
    cheers
    yeah wheels off is easier mate, and impossible to fit at the rear without doing so. Beware though, as I found out the car sits a lot lower than you think when you put it back onthe ground and then sit in it... I had to take my front ones off again cos I'd put them on too low and were scraping the ground the entire time...
    well, having seen VX's 'instructions' again today all i can say is what a pile of carp..
    for the fronts, attach the plastic clip to the side sill over the tiny screw hole, then screw the bottom in first.. then push the mudflap round on to the innerwing, so it fits nicely round the wing..drill through the holes in the mudflap and into the plastic inner wing with an 8mm drill, install the plastic rivets..
    Rears, unscrew the edge of the bumper from the inner wing liner..pull the bumper slightly out and swap the retainers for the supplied ones, then just screw the mudflaps back into these holes, but putting the supplied spacer between the mudflap and the arch liner..finally bend the tab back up onto the lower bumper, drill an 8mm hole and install the plastic rivet..
    thats why I chose cheap ones mark.. 3 screws in each..lol..job done!
  1. Fitting Mud Flaps
    By k.coupe in forum Styling
    Last Post: 3rd March 2012, 16:23
  2. Now fitting C/C'd mud flaps.
    By connery-sri in forum Vectra C / Signum Car Chat
    Last Post: 17th March 2010, 12:38
  3. Help needed fitting mud flaps to Vectra C SRi
    By OSSY in forum Vectra C / Signum Car Chat
    Last Post: 11th December 2009, 17:26
  4. Astra mk 3 flaps fitting tips needed !
    By Kcs in forum Vectra C / Signum Car Chat
    Last Post: 7th February 2008, 20:40
  5. Mud flaps fitting advice please
    Last Post: 3rd February 2008, 17:10
how to fit flappy mud flaps
