Thread: Rear Brake Piston - turns but won't push
    Jan 2008
    Nr Oxford
    confused Rear Brake Piston - turns but won't push
    Hi all,
    I'm trying to change the rear pads on my 52 plate Vectra. Got the pads off easy enough and tried to push the caliper back in. No joy. So I figured they were of the screw-in type. Several minutes of turning and they were no further in.
    I then tried compressing them with a G-Clamp. No Joy. Anyone got any suggestions as to what I try next? Is this simply siezed/dead? I've never had anything like this much trouble changing pads on anything before, not even Citroens!
    Help ! ! ! (Please)
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    the brake piston is on a fine thread so you need to get a brake calipe wynd back tool because it pushes and turns at the same time
    this is it
    http://cgi.ebay.co.uk/vauxhall-Vectr...QQcmdZViewItem
    yep, put that g clamp away!!!!.. you MUST use the correct tool..
    hopefully you haven't wrecked the calipers internal thread with the g clamp's pressure....
    Jan 2008
    Nr Oxford
    Hi,
    The ebay link says 'adapter only' which suggests I need to buy >1 thing? I don't suppose Halfords would stock a suitable tool? The pads are too worn to put back on and I need the car back on the road asap - like by Monday.
    Jan 2008
    Nr Oxford
    Would help if I read all of the ebay listing!!!
    lol, yes halfords to also sell the tool, just not the correct adaptor.....they sell their tool for £20...
    11 Post(s)
    While you're at it, clamp the flexible brake pipe and release the bleed nipple. This will save you having to push the brake fluid allthe way back to the master cylinder, and will also prevent the risk of flipping the rubber seals as well.
    Jan 2008
    Nr Oxford
    Hi all,
    Thanks for the advice. Tool arrived on Saturday morning, job done nice and quick.
  1. Is the seal for the piston on the rear brake calliper glued on ?
    By siadwel in forum Vectra C / Signum Car Chat
    Last Post: 22nd July 2012, 18:47
  2. Rear brake pads don't fit holes in piston
    By sharp114 in forum Suspension, Wheels & Brakes
    Last Post: 17th July 2012, 16:49
  3. seased rear brake piston
    By leedrummond in forum Suspension, Wheels & Brakes
    Last Post: 12th May 2012, 20:07
  4. rear brake piston
    By guitarbaz in forum Suspension, Wheels & Brakes
    Last Post: 18th October 2010, 16:44
  5. rear brake piston rewind
    By Troutfisherman in forum Suspension, Wheels & Brakes
    Last Post: 10th March 2010, 19:59
can vectra c rear brake be pushed in
