Page 1 of 5 123 ... LastLast
Results 1 to 10 of 41
Thread: Clay?
    Regular Member Stuarty's Avatar
    Aberdeenshire
    Default Clay?
    I have seen you guys mentioning clay bars,i have had a look in halfords and some other shops around me and i cant find it anywhere,Could someone post a link to where i can get it from also any chance of someone telling me what it does and what is the best way to use it to get the best results.
    Regular Member Harry's Avatar
    Uxbridge, London
    check this out:
    http://www.elitecarcare.co.uk/produc...roducts_id=263
    gives a nice description of what it does. that particular kit is the one that most halfords do and is a good starter kit as it comes with the lubricant that you need to use plenty of.
    type clay into the search function and i'm sure you'll get some good results as to how best to use it.
    cambs
    hi
    i used for the first time a couple of weeks ago
    and i cant belive how much crap was left on the car.
    just wash car
    use liquid and spay the part about to be clayed
    flaten clay and then rub over the area just sprayed
    and when clay is dirty fold and flatten again
    and continue all over the car
    1 bar should be enough to do a car
    wash car again
    polish and wax
    it does take a long while but well worth it
    Before you do the car though, after washing and drying try lightly rubbing the surface with a piece of plasic wrapping paper, like you get round a fag packet, you will feel how rough the paint is, then try again after claying, smooth as a babies bum !!
    Aberdeenshire
    Ok so it decontaminates the paint then does it remove tar spots and the like or will they have to be removed first?
    Uxbridge, London
    it removes them too
    Tyneside
    Best to use a tar remover to get rid of tar spots and then your not clogging up the clay with clumps of tar, but if they are stubborn and the tar remover doesn't budge it the clay probably will.
    It will remove a few , but to save the clay getting gunked up best to remove them first . Autosave on riverside drive sells the megs kit, have you tried them ??
    Forum Moderator FIL 4822's Avatar
    On a French Carp lake somewhere x
    6 Post(s)
    Vehicle : Insignia VX-line RED Tourer
    Trim : No, over weight!
    Engine : Flux Core Capacitor
    Year : 1 A.D
    Mileage : Rising
    Stu, the most important thing of all is if you drop the clay bar, throw it away, it'll pick up every piece of grit it touches and then you'll rub it across the paintwork and do unrepairable damage to the surface ! Be warned !!!
    Halfords kit is a good starter.
    One more important piece of information, YOU ARE ENTERING THE VERY ADDICTIVE WORLD OF DETAILING, IT CAN GET EXPENSIVE !!!!
    PHIL.
    Tyneside
    Very expensive, I started off with claying a few months ago. I now have over £200 worth of detailing kit and thats nothing compared to some guys.
  1. To clay or not to clay?
    By rob warrington in forum Detailing and Car Care Discussion
    Last Post: 28th December 2011, 19:13
  2. Gonna take you to a clay bar, clay bar CLAY BAR!!!
    By peppered in forum Detailing and Car Care Discussion
    Last Post: 7th September 2009, 21:11
  3. Clay - WOW!!
    By davree in forum Detailing and Car Care Discussion
    Last Post: 16th March 2009, 14:24
  4. Clay Day
    By T4M in forum Quick Photo Album
    Last Post: 6th May 2008, 19:15
  5. What Clay??
    By DeathStar in forum Detailing and Car Care Discussion
    Last Post: 27th January 2008, 23:58
