guys i need the torque settings for the bolts at the top of the shock towers. can anyone help. also if i take them out for a min with the car flat on the ground and dont move it will it be ok and then ok to put them back in?
comeone someone must know i need to know asap
you can take them out, no problem..the strut self centres due to a cone in the strut towers hole, and a matching one on the struts top plate..
if you're taking out the bolts to fit a strut brace, just make sure they are long enough to locate the strut top still, after passing through the brace..
they are indeed M8....and yes, just change them for a longer hexagaon headed bolt..
