Thread: Torgue settings needed
    Regular Member aerodynamic18's Avatar
    Aug 2007
    Lisburn, N.Ireland
    Default Torgue settings needed
    guys i need the torque settings for the bolts at the top of the shock towers. can anyone help. also if i take them out for a min with the car flat on the ground and dont move it will it be ok and then ok to put them back in?
    Aug 2007
    Lisburn, N.Ireland
    comeone someone must know i need to know asap
    [Ex]Admin Duncan's Avatar
    20 Nm + 45° + 15°
    Quote Originally Posted by aerodynamic18 View Post
    you can take them out, no problem..the strut self centres due to a cone in the strut towers hole, and a matching one on the struts top plate..
    if you're taking out the bolts to fit a strut brace, just make sure they are long enough to locate the strut top still, after passing through the brace..
    spoons
    Guest
    ...if you're taking out the bolts to fit a strut brace, just make sure they are long enough to locate the strut top still, after passing through the brace..
    I was talking with Nigel at 888 Race Engineering today about this very same subject.
    He reckons the Torx bolts are something like M8 thread, and can be replaced with another bolt just a bit longer to allow for the thickness of the strut brace.
    they are indeed M8....and yes, just change them for a longer hexagaon headed bolt..
    Regular Member hans_vledder's Avatar
    't Veld - The Netherlands
    20 Nm + 45° + 15°
    Hi,
    This 20Nm I get, but what is this + 45° + 15°?
    Cheers,
    Hans
    Quote Originally Posted by hans_vledder View Post
    Hi,
    How far you've got to then rotate the spanner / socket wrench after you've torque'd up the bolt.
    ... with some time in between to let the whole thing settle I guess?
  1. Car Vs Kerb! Torque settings needed please.
    By 19CDTi in forum Suspension, Wheels & Brakes
    Last Post: 9th January 2013, 11:54
  2. NAT settings
    By Guyver1 in forum Games Room
    Last Post: 26th March 2009, 11:36
  3. Tyre pressure settings needed asap.
    By FIL 4822 in forum Vectra C / Signum Car Chat
    Last Post: 15th August 2008, 21:07
  4. Torque Settings Needed Again
    By mark1319 in forum Handling & Braking
    Last Post: 25th January 2008, 01:21
  5. tracking settings
    By Higgins in forum Vectra C / Signum Car Chat
    Last Post: 20th January 2007, 15:52
