Results 1 to 10 of 14
Thread: Heated mirror not heating up.
    Jan 2008
    Derby
    confused Heated mirror not heating up.
    Hi to all
    I wonder if someone could help me out.
    I have a 2004 sxi with heated mirrors and the drivers side is not heating up.but the passenge and heated rear window are.
    Is there a seperate fuse as I can not find it.
    I have tested the voltage at the mirror and there is no voltage.
    I have also tested the resistance of the element and it is 11 ohms is that ok.
    Thanks for help on this steve.
    Sunny Dartmoor
    Didn't know they did,will have to check mine now........
    [Ex]Admin Duncan's Avatar
    Are the rest of the door/mirror functions still working? Just trying to rule out a Driver's Door Module (DDM). That's a 30A fues (#15) in the compartment behind the side of the passenger side dash.
    If that's not it, you may have a break somewhere - may need to follow the wire back to find it.
    Jan 2008
    Derby
    Thanks for info.
    Mirror motors work ok just the heating element will have to take door skin off I think.
    Does anyone know if there are any fuses in door module.
    Thanks.
    Nope, no fuses in door module or door.
    Regular Member Karl's Avatar
    Sunderland
    if there's no power going to the mirror element then you either have a broken wire or a fuse out, sounds like the fuse is ok, so I would have thought you have a crimped/cut wire.
    Jan 2008
    Derby
    confused
    Hi
    I have just had door skin off and checked wire direct to element from door module plug and all is ok.
    Does anyone know if there is anything that I can check before door module or is the door module looking like the cause.
    Thanks steve.
    i take it you've taken the mirror glass out and checked the two wires are still connected to the terminals and they're not corroded...or it could be as simple as a bad contact on the back of the glass, where the spade connector attaches..
    Regular Member shan's Avatar
    I'd check that the element in the glass is ok. Maybe the element is open circuit.
    I thought he'd tested the voltage on the wires connectors already?, hence ruling out the actual connectors on the mirror.
  1. Heated mirror
    By patch22 in forum Vectra C / Signum Car Chat
    Last Post: 26th December 2012, 22:00
  2. Heated seat drivers backrest not heating?
    By ronnie63 in forum Bodywork & Interior
    Last Post: 4th December 2012, 14:30
  3. Passenger heated seat not heating
    By VeccyMike in forum Bodywork & Interior
    Last Post: 20th November 2012, 09:33
  4. heated mirror
    By keggy77 in forum Vectra C / Signum Car Chat
    Last Post: 17th January 2012, 20:27
  5. Heated mirror fuse
    By Daywalker in forum Electrical & ICE (including SatNav)
    Last Post: 20th March 2010, 20:26
vectra c mirror dont heat
vauxhall insignia heated mirror fuze
