Thread: Servicing.
    Jan 2008
    West Wales
    Default Servicing.
    Evenings...Trust you are all well.
    Does my car have one of these DPF's and what is the recall I am reading about?
    Mine is an 05 Cdti 1.9 (Elite).
    Also - the dealer "none" Vauxhall I bought the car from serviced the car as part of the sale but the spanner comes on when you first turn on the ignition which I thought meant less than 600 mile to next service.....
    Car is on 63K but was services by Vauxhall last year on 54K?
    I am thinking of getting the car into Vauxhall or a friends garage for a better oil change - what is best to use with the Cdti as I have heard they perform better with certain oils?
    I may as well get the cambelt done as well - I know it's not due for a while but "might as well".
    What would the engine benifit from servicing wise - other fluids have been done by the dealer I purchased it from - happy to use these.....
    What will be tired on a 60K in 3 yrs Cdti (all be it an Elite which "may" I hope have had an easier life)
    Rgs
    Bobby
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    DPF only on signum's and vec estates afaik and an update to burning software or something or other need's doing
    i run my cdti on 10w/40 semi synthetic changed at every 10k miles dealer advised, some say it's no good and use 05w/30 fully synthetic only...
    hth
    Midlands Mod Shop - NFFC.
    Jan 2008
    West Wales
    Mine is an 05 Elite estate so does that mean I need to check in with them?
    So a 10/40 semi or a 5/30 full...
    I have not idea what the seller used but I bet it was not a top shelf oil!.
    Rgs
    Bobby
    Trim : Get a
    Quote Originally Posted by bobby_rstevens View Post
    Rgs
    Bobby
    just have a chat to the dealer's and they will sort it all out for you mate
    Bobby,
    for the DPF equipped cars, 5W30 fully synth from VX , changed every 10,000 miles is the only way to go....the DPF is sensitive to the sulphur content of oil and VX's brew reflects this...yes it's a bit dearer, but way cheaper thanm having DPF problems out of warranty
    PS.. they haven't reset your service indicator, thats all..
    Jan 2008
    West Wales
    So how can I tell if my car has DPF? is this just like a fancy cat? or is it some kind of re-circ....(great!)
    Sorry for my lack on knowledge.
    Rgs
    Bobby
    As its an estate I would have thought it would have one. Someone posted a pic of one the other day. Its in the exhaust. Looks a bit like a cat but with a couple of pipes going to it. hth
    Jan 2008
    West Wales
    I am appauling at searching forums!!!...
    Can a forum wizard find the link and attach. I had a look under the car and can see what looks a normal cat but my mech knowledge is not great.
    Looking in the service stamps it looks to have had 10/40 oil - defo counter on the car as the Insp has also come up aswell which tells me the car thinks it needs a service.
    £128 in the local VX place for a 5/30 service and cam belt change is £180 I think.. They said I will need a recall on the handbrake when the paperwork comes in but they are not aware of any recall's on DPF's.... if I have one.
    Rgs
    Bobby
    Have a look HERE
    Its not the pic I was after but I'll keep looking. It does give some VIN plate info.
  1. Servicing
    By mickg in forum Vectra C / Signum Car Chat
    Last Post: 8th August 2012, 19:27
  2. Servicing
    By ADAM123 in forum Engine & Drivetrain
    Last Post: 12th March 2010, 13:45
  3. Servicing
    By Ben999 in forum Vectra C / Signum Car Chat
    Last Post: 25th March 2009, 14:43
  4. servicing
    By stuart bigboy in forum Vectra C / Signum Car Chat
    Last Post: 24th February 2008, 10:23
  5. Servicing
    By VECTRAMAN in forum Vectra C / Signum Car Chat
    Last Post: 6th November 2007, 21:06
