Thread: Can you work this out?
    Regular Member Dave1.8's Avatar
    Oct 2007
    Ellesmere Port
    Default Can you work this out?
    U2 has a concert that starts in just 17 minutes and all of the band members must all cross a bridge to get there. The four men begin on the same side of the bridge and you must help them to get across to the other side.
    Due the age of the bridge, a maximum of two people can cross at one time. To make matters worse, it is night-time and there is only one torch. The torch is always required when crossing the bridge and the torch must be walked back and forth, it cannot be thrown, etc. Each band member walks at a different speed and a pair must walk together at the rate of the slower man:
    Bono takes 1 minute to cross
    Edge takes 2 minutes to cross
    Adam takes 5 minutes to cross
    Larry takes 10 minutes to cross
    For example, if Bono and Larry walk across first, it takes them 10 minutes to cross. If Adam then returns with the torch, a total of 15 minutes will have passed. There is no trick behind this, it is the simple movement of resources in the appropriate order.
    [Ex]Admin Duncan's Avatar
    Bono and Edge cross (2 mins), Bono returns (1 min), Adam and Larry cross (10 mins), Edge returns (2 mins), Bono and Edge cross (2 mins) - 17 minutes.
    - just a case of taking advantage of the two quickest crossers, and grouping the two slowest.
    Oct 2007
    Ellesmere Port
    That was just a warm up one You will never get the next one
    Regular Member lofty's Avatar
    @home
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTi
    or.... they play Bass Trap as their first song..
  1. Spanner light while driving to work with no code and usually same point when driving to work?
    By rollercoaster63 in forum Vectra C / Signum Troubleshooting
    Last Post: 6th July 2012, 21:52
  2. will this work?????????
    By glynn in forum Vectra C / Signum Car Chat
    Last Post: 19th May 2009, 21:06
  3. To work or not to work that is the question
    By garvey in forum The 'Off Topic' room
    Last Post: 31st December 2008, 19:02
  4. warranty work paper work ???
    By Gr4eme in forum Vectra C / Signum Car Chat
    Last Post: 28th October 2008, 00:21
  5. Anyone else still at work...?
    By izonoky in forum General Chat
    Last Post: 24th December 2007, 13:35
