Thread: Heater Switch Problem
    Feb 2006
    Bristol
    Default Heater Switch Problem
    Hi all,
    I have a Vec-C 05 SRI with manual AC. The fan only works when the dial is in position 4. I am at 67K miles.
    This exact same problem happenned before at approx 30K. When I had it repaired under warranty, the garage knew exactly what to do before even looking at the car (said something about a blown resistor), suggesting to me it was a common fault - confirmed by it happenning to me again!
    So I have 2 questions:
    - Whats my warranty on my car? Am I still covered?
    - Does anybody have any info / fixes for this fault?
    Many thanks,
    Phil
    Sunny Dartmoor
    Quote Originally Posted by precesh View Post
    Hi all,
    Many thanks,
    Phil
    Am right in stating that as you car has done over 60k its out of warranty.
    Yes its the resistor pack for the heater/blower,common fault as you said,think cost was under a tenner,but not 100% sure.
    I would ring the garage who did the repair and ask them if they'd share the cost of it as a good will gesture,worth a try.....
    If not do a search for resistor pack and see whats involved,good luck......
    Feb 2006
    Bristol
    Thanks for that.
    It appears that I have to go in through the glove box so I'll have a go at the weekend.
    Phil
    Feb 2006
    Bristol
    Just found out £22.30 + vat!!
    Has anybody tried replacing with standard RS resistors? Or worked out the resistor values?
  1. Please help, heater problem
    By foxyland in forum Electrical & ICE (including SatNav)
    Last Post: 13th December 2012, 08:47
  2. Heater switch problem (Fan)
    By Badger59 in forum Vectra C / Signum Car Chat
    Last Post: 21st January 2011, 09:49
  3. My heater postions take forever to switch over
    By Matty H in forum Vectra C / Signum Car Chat
    Last Post: 17th July 2008, 21:20
  4. Heater Control Switch Panel
    By leeds vectra in forum Parts for sale
    Last Post: 22nd January 2008, 03:18
