Thread: Steering rack play
    Regular Member K18 JRT's Avatar
    Oct 2006
    exeter
    Default Steering rack play
    Just had MOT which it passed but got an advisory O/S and N/S steering rack ball joint with slight play.
    Is this something that will cost a packet next year,like a new steering rack or is there some kind of repair kit for this.
    I asked if he meant track rod ends and he said no,its play in the rack.
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Well I thought the rack was hydraulic?
    Regular Member platty's Avatar
    Jan 2008
    Paisley
    Could be the track rod itself (not the ends), I have just replaced this myself after a shunt with a kerb. It bolts on to the steering rack, it has a ball joint you can see it if you remove the gaitor. pretty easy job to do. Mine cost £27 pounds from the dealer or you can get one from a motor factors about £15.
    Quote Originally Posted by K18 JRT View Post
    yep, the inner joints will have worn...kits from VX are model specific, so you'll have to take your VIN number in...worst case £26.25+V a side
    It is Rushy, this is the mechanical link from the end of the rack bar to the track rods..the 'hydraulic' only ever referred to the assistance...
    Quote Originally Posted by platty View Post
    Top bloke.....yep, easy to do and only about ££600 cheaper than a new rack....
    Oct 2006
    exeter
    Thanks for the replies guys,that was what i was hoping would be the case.
    The price of a new rack made me feel quite ill,the MOT tester said there was no parts available for this and insisted it would need a new rack.
    Default Special Tool for Inner Track Rod Ends
    I've been told that a special tool should be used to fit new inner track rod joints on my Vectra. (Apparently using a pair of stillson's instead often leads to a tight or ******ed steering rack). Anyone know anything about this tool, or how much it typically costs?
    scunthorpe
    how did you change your rod from above or bellow mine seems to be obstructed by the gearbox and abs control vave block
    Jan 2008
    Paisley
    Hi mate, It's been a while since I did mine. as i recall I gained access from the wheel arch and used one of these http://www.halfords.com/webapp/wcs/s...egoryId_165469 to get the rod off. this was for the o/s. I can't give any advise for n/s. Hope this is of some help.
  1. MOT advisory... Play in steering rack joints
    By DNS in forum Suspension, Wheels & Brakes
    Last Post: 11th January 2012, 21:43
  2. mot advisory offside inner steering rack joint has slight play
    By wiganrl in forum Vectra C / Signum Troubleshooting
    Last Post: 5th May 2011, 12:29
  3. Play in steering rack? Vec C
    By Mopar Man in forum Suspension, Wheels & Brakes
    Last Post: 14th March 2011, 19:19
  4. Replies: 6
    Last Post: 13th March 2011, 10:47
  5. steering rack play, maybe?
    By iasha in forum Vectra C / Signum Troubleshooting
    Last Post: 30th January 2011, 21:28
vectra c steering rack movement
steering rack movement 2000 vectra
vectra c steering free play
