Results 1 to 10 of 14
Thread: Headlights
    Regular Member StephNET's Avatar
    Wiltshire
    Question Headlights
    Has anyone fitted the 80watt 'off road' replacement headlamps that halfords sells on a pre facelift Vectra? Can the electrics handle the extra load? I would have to change the 10amp fuse for a 15amp fuse as the brighter lamps would increase the load from 9.5 amps up to 13 amps. Do they generate a lot more heat? Enough to damage the housing?
    People have fitted higher wattage bulbs - can't recall which exact wattage - and it's started to fry the wiring on the headlights!
    Jul 2006
    Mexico
    it`s not the fuse....it`s the gauge that it`s limitted to the current load.
    Regular Member Signum_CDTI's Avatar
    May 2007
    Somewhere and Nowhere....
    Wiltshire
    I was afraid that would be the case. My next idea would be a 40a relay with appropriate wiring, but then I'll have to deal with that warning light constantly throwing a wobbly.
    Jul 2006
    Mexico
    Probably so mate....and I dont know how Canbuss affects what you mentioned...
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    I've run a 100w bulb on my motorbike for the past 7 years, original was 55/50. All I did, on advice from Kawasaki, was to apply copper grease to the bulb connector block to dissipate the heat. Not had a single problem.
    Food for thought but I'd still go down the relay route on a car just to be on the safe side.
    Wiltshire
    If I recall from reading other posts, you have to either leave the original lamp taped up some where, our use a resistor or combination of resistors to fool the computer into thinking that there is a 'good' lamp installed
    Regular Member billyyoung's Avatar
    dundee
    i know this may seem a silly question but why fit the 80w off road bulbs when you wont be off road and they are illegal to use other wise. it is just a comment or maybe me being an old git and realising all the times i was stopped when i was younger and fined of illegal stuff on my car ie neons long before fast and furious , coloured side light bulbs , fog lights on etc .
    Regular Member beefycol's Avatar
    Nov 2007
    telford
    i got 100w bulbs in there fine, but the 80w road bulbs ment to damage your head light reflectors too, plus there illegal on a public road. im gona go for the hid conversion
  1. LHD / RHD Headlights
    By 24vElite in forum Electrical & ICE (including SatNav)
    Last Post: 10th February 2011, 19:46
  2. headlights
    By SimonL in forum Vectra C / Signum Car Chat
    Last Post: 26th December 2010, 12:50
  3. headlights dim
    By iasha in forum Electrical & ICE (including SatNav)
    Last Post: 20th January 2010, 16:26
  4. SRi Headlights
    By Danwells72 in forum How much is it worth? (THIS SECTION IS NOW CLOSED)
    Last Post: 20th October 2008, 09:11
  5. Headlights
    By steve in forum Vectra C / Signum Car Chat
    Last Post: 6th January 2008, 17:55
