Thread: Interior Problems....
    spoons
    Guest
    Default Interior Problems....
    I'm selling my leather interior out of the VXRD and the new buyer has a pre-facelift SRi interior that he wants to swap.
    They look absolutely identical except two things.
    1) Front passenger electric control switch on door panel is slightly different.
    2) All 4 door panels have a different plastic trim (along the top edge of the door card)
    Question is... than these above bits be swapped, so that the 'leather' seats and door cards can be transferred ?
    [Ex]Admin Duncan's Avatar
    1) The switch is different, (as the pre-facelift had the boot unlock button) but isn't the mounting insert/hole size still the same on the door cards?
    2) Do you mean where the door pins stick through? If so, then I don't think it'll be swapable.
    spoons
    Guest
    Just had a phone call off Maverick and it appears that it wont work... so cheers anyway folks...
    Which bit? The trim or the switch?
    spoons
    Guest
    The switches simply detach, so can remain on the original car. Just the cards can be swapped.
    Where is all goes wrong (in this instance) is the plastic trim on the door cards. On the pre-facelift its completely different design and colour to the facelift.
    Matt also had a concern over the seat airbags and wiring loom compatibilities (canbus etc).
    So best left alone.
    My interior is still up for sale here http://forum.vectra-c.com/showthread.php?t=38070
    ... but I need to find someone who has a facelifted SRI vectra to swap with...
    Quote Originally Posted by spoons View Post
    Yep, that's what I was meaning/thought.
    Right.
    So best left alone.
    Indeed, especially if there's any doubt.
  1. Rear interior light problems
    By sriandy in forum Electrical & ICE (including SatNav)
    Last Post: 24th September 2012, 22:53
  2. z18xer vvti, problems, problems
    By gstore in forum Engine & Drivetrain
    Last Post: 20th April 2012, 13:33
  3. crusie control problems, anyone had similar problems?
    By rozzer2006 in forum Engine & Drivetrain
    Last Post: 2nd October 2011, 21:20
  4. 1.9 cdti auto problems problems
    By trigger in forum Engine & Drivetrain
    Last Post: 28th September 2009, 17:20
