Thread: Spanner Light
    Regular Member Stevie-B's Avatar
    Mar 2007
    NI
    Default Spanner Light
    The spanner light came on and the car went into 'limp mode'. So I re-set the service interval and noticed as I was waiting for the ecu to re-set that a 21.00 was displayed below the spanner symbol. Has anyone seen this before?
    Also rang a local garage who can read CAMBUS and he told me because I re-set the service interval no fault codes would be stored is this true? I could'nt keep it in limp mode.....
    Regular Member DeanF's Avatar
    Nov 2007
    Staffordshire
    Quote Originally Posted by Stevie-B View Post
    Isn't the 21.00 that was displayed the Max mile Service interval before the service light/icon is displayed in the Tacho, Telling you to get it serviced.
    I believe if you hold it in for longer it will then jump up another 10 to 31 Etc..
    Did it drive like it was in Limp Home mode ??
    Dean
    Melbourne, Australia
    As far as I know, the only way to cure limp home mode is to cure the problem that's causing it!
    Regular Member v6diesel's Avatar
    Southampton
    Apologies for the stupid question as its probably been covered a load of times before, but how do you reset the ECU and service interval? are special tools needed ??
    the ECU can be reset by the simple job of removing a battery lead for 10 mins, then reconnecting.. all old fault codes will be deleted and only current ones remain..
    to reset the service interval, press down the brake pedal and hold, press the trip reset on the speedo and hold, turn ignition key to posn2 and after about 10 seconds the display in the speedo will change to show the new service mileage....turn off ign and release the button and pedal..
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Problems with Air bag light, ABS, Anti Skid & Spanner light
    By WeDesign in forum Vectra C / Signum Car Chat
    Last Post: 4th December 2012, 21:23
  3. Should I Have A Spanner Light aswell as an Engine Light on My Signum?
    By StreetDragster in forum Engine & Drivetrain
    Last Post: 18th August 2012, 11:57
  4. EGR Valve, Engine Management Light & Spanner Light
    By guygreen in forum Engine & Drivetrain
    Last Post: 12th December 2010, 20:09
  5. spanner light then engine management light
    By learoy69 in forum Engine & Drivetrain
    Last Post: 12th March 2010, 20:10
