Results 1 to 10 of 11
Thread: high pitch noise
    Jun 2007
    west yorkshire
    Default high pitch noise
    Hi
    i have noticed recently that when driving my car for a while it makes a high pitch noise. when i brake or turn my sterring to the right it stops
    what could that be?
    cheers
    tj
    Regular Member beefycol's Avatar
    Nov 2007
    telford
    its your brake pads that making the noise, and as for what is making then make a noise could be a number of reasons, dust, brake pads getting low (but usly hear a griding nice then) it will go way in time nothing to worry about. had it plenty of times, bit embrassing when you go through town because people look and they think your cars falling apart. sure someone will confirm me on that
    Regular Member Itsallrover's Avatar
    Aug 2007
    in an M&S somewhere in the South West
    I was thinking low power steering fluid......?
    Nov 2007
    telford
    Quote Originally Posted by Itsallrover View Post
    could be, but the reason i fought the brakes is because its happened to me before few times, and when i braked and turned a corner it would stop, first time was needed new brake pads, other time just been dust but went after a couple of days
    Jun 2007
    west yorkshire
    yeah might be dust but it doesnt happen all the time when driving only if ive been braking hard! but it comes and goes! but at high speeds its ok its only when u drive at low speeds!
    if it was power steering fluid wouldnt it happen all the time even when cars cold?
    Nov 2007
    telford
    yeah sounds like the brakes to me, that happened with me to when it went over about 50mph the noise went, and came back when going around town. but id just give your car a quick check over, fluids and brakes (see if they getting low)
    Jun 2007
    west yorkshire
    yeah will do this lunch time!
    i know the pads were chanegd last year around march time
    and i got the back pads changed and front ones checked about 1 month ago and they were ok i will check all fluids
    Jun 2007
    west yorkshire
    just checked the bradke fluid and its topped up so thats ok
    so in order to get rid of dust do i need to just wipe it????
    Nov 2007
    telford
    you could give the disks a quick wipe doubt that will do my tho, it will go on its own
    if it's making the noise, it's the pad rests and caliper faces that need cleaning.. then reassemble the brakes with a smear of copper grease wherever the pads touch the pad rests and the back of the pads..
  1. Noise from engine. May be high oil pressure.
    By Shaben in forum Engine & Drivetrain
    Last Post: 18th May 2012, 19:36
  2. High pitch noise
    By shaun_richmond in forum Suspension, Wheels & Brakes
    Last Post: 13th May 2012, 19:46
  3. high pitched noise
    By drivemyvectra in forum Vectra C / Signum Troubleshooting
    Last Post: 19th May 2011, 16:40
  4. Metallic High Pitch Squealing Noise
    By CarlM in forum Suspension, Wheels & Brakes
    Last Post: 12th June 2009, 20:11
  5. high pitch squeal coming from front??
    By KevinG in forum Engine & Drivetrain
    Last Post: 28th February 2009, 17:42
