Results 1 to 2 of 2
Thread: Suspension springs - general
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Default Suspension springs - general
    I need to lower my other cars front end by about 40mm, as I have fitted a 3.5 litre Rover V8 engine as a replacement for the standard 3 litre V8. The RV8 weighs about 60Kg less, so the front end is high.
    The springs are standard coil springs of uniform coil diameter from top to bottom (ie NOT progressive).
    Would it be acceptable to simply cut 40mm off one end? I realise that this will also make the spring stiffer, but are there any pitfalls if I 'dress' the cut end?
    Obtaining shorter springs of the same rate as standard is proving almost impossible.... at a reasonable cost anyway.
    TIA
    Regular Member Gregg's Avatar
    Aug 2007
    Great Wyrley
    pretty sure cutting springs is not advised.
    My mate had some standard springs shortened by a company in West bromwich, they heat them up and shrink them down. something like that would be safer for sure
  1. Anyone used LO Suspension springs?
    By Coupe2T in forum Suspension, Wheels & Brakes
    Last Post: 2nd April 2012, 20:23
  2. Opinions on new suspension and springs
    Last Post: 6th September 2008, 15:55
  3. help, need suspension springs
    By mooney in forum Vectra C / Signum Car Chat
    Last Post: 16th August 2008, 22:23
  4. Koni Suspension Springs Kit
    By coopster in forum Handling & Braking
    Last Post: 11th April 2008, 10:32
  5. Koni Suspension Springs Kit
    By coopster in forum Suspension, Wheels & Brakes
    Last Post: 6th April 2008, 00:33
