View Poll Results: An odd one
Voters
75. You may not vote on this poll
  • Nothing, it will stay the same
    18 24.00%
  • The room temp will increase over time
    49 65.33%
  • The room temp will decrease over time
    8 10.67%
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 37
Thread: An odd poll, from an odd person !
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Default An odd poll, from an odd person !
    This is a poll to get answers from people on a common problem . . . . (I said it was an odd poll for my first poll on here)
    Consider ......
    A fridge, with the door wide open, is placed in a room that is completely perfectly thermally insulated (ie NO heat transfer into / out of the room).
    When the temperature had completely stabilised in the room the fridge was turned on, what would happen to the room temperature over time??
    I'll give the correct answer later.....
    Feb 2007
    North west
    It would warm up. The appliance is not efficient enough to cool in equal volumes to the heat it generates in running.
    Admin plasma's Avatar
    On the Forum
    291 Post(s)
    Engine : 150
    Mileage : 74000
    Its to do with effiency i think. Nothing it 100% efficient, there is always a loss. so more power would be used in order to try to cool the room. thus giving off a greater heat to coolness ration, so I reckon the room would get warmer... Or i could be talking a load of old crap
    member of the smoke patrol 230bhp+
    its a fake
    you need to know the temperature of the room
    and you also need to know the temperature setting on the fridge it may never switch on
    Nicking Ya Dinner.
    Ok I'm in.
    The fridge will not make cold air as the door is open and anything above freezing point in the room will ensure that the fridge has no chance of making and cool air, almost like one bloke trying to move 5 blokes, they cancel him out due to mass and volume, then the heat generated by the coolant radiator should increase the room temp as the room is sealed so the heat cannot escape.
    That's my answer and I'm sticking to it even if it maybe Wong said Mr Woo.
    EVERYWHERE
    And what is the "stabilised" room temperature?
    However,since a fridge works by removing heat from the atmosphere,I would say that so long as the fridge actually works,it will make the room colder.
    Think aircon.
    [Ex]Admin Duncan's Avatar
    If we're assuming that the fridge's thermostat is set such that it will turn on - which it should do given the range of fridge thermostats - then the room will gradually warm up. Basically the heat generated by the heat exchanger in trying to cool the ambient air entering the fridge is more than any cooling effect of the inside of the fridge on this air - so the room will gradually warm up, and you'll also have a larger electricity bill!
    EVERYWHERE
    How big is the "room" ?
    The question leads me to believe that this doesn't really matter.It could be slightly bigger than the fridge with its door open or an aircraft hangar,the effect should still be the same.
    Regular Member fenderguitar's Avatar
    Portadown Co. Armagh N. Ireland
    [quote=diesel dog;464592]How big is the "room" ?
    What make is the fridge
    Full Member VectraMat's Avatar
    Hull
    How big is the fridge - for example it could be one of those mini fridges (as used by top gear for the super cool db9 section of the cool wall) of an industrial fridge used in cold stores?
    i think once we know this we will be able to figure out the correct answer....
    VXR Gone - Now in BMW 320cd M Sport Convertible
  1. New person thread
    By jamie27 in forum Introduce yourself.
    Last Post: 22nd April 2009, 16:05
  2. new type person
    By ptrehearn152 in forum Introduce yourself.
    Last Post: 29th January 2009, 15:25
  3. An odd poll, from an odd person ! #2
    By VauxVeteran in forum General Chat
    Last Post: 16th January 2008, 20:12
  4. Replies: 12
    Last Post: 5th December 2007, 01:47
  5. Missing Person
    Last Post: 31st August 2007, 21:04
