Thread: Auto gearbox thumping in and out of 3rd gear
    Jan 2008
    Widnes
    Unhappy Auto gearbox thumping in and out of 3rd gear
    Hi all, new to the Vectra (6 weeks) just noticed thumping in and out of third gear in 6 speed auto box - 1.9 CDti 150, read many threads so far and fear the worst, car just out of manufacturers warranty but reported problem to VX dealers three days before hand - arranged visit to demonstrate problems and you guess it, none could be found or demonstrated. Problem appears to be first 10 - 20 minutes from stone cold, warm engine and box seems less of a problem. Any ideas please - would be very much appreciated, sharp knife and wrists ready as an alternative - only joking, honest.
    has it flagged a gearbox fault...??..if it has , then the answer is stored in the gearbox ECU's..and TECH2, or a similar system will reveal what the fault is..
    Jan 2008
    Widnes
    Thanks for the reply, Tech 2 has been connected and no faults where found, have driven about 300 miles today and gearbox has been generally fine, on this basis I am wondering if the colder weather over (particulalrly over the Christmas period has been having an effect), when it last happened outside temp was around 3 - 3.5 deg, today been around 8 - 9 deg, will keep an eye on this one.
    cold weather may point to problems with the valve body on the auto trans...
    Have you got a local automatic gearbox specialist ( yellow pages) that you could try..they often know FAR more about the automatic gearboxes than the VX Techs..
    Jul 2006
    Mexico
    Sounds like something I have on my beast...with a difference that is on 2nd gear not on 3rd.
    I might suggest a change of oil to the box...which I need to do BTW
  1. M32 gearbox can`t get gear selector back in gearbox HELP!
    By v33tra in forum Engine & Drivetrain
    Last Post: 30th March 2017, 07:43
  2. Vectra C Auto Gearbox - Jumps While Going From 3rd to 2nd Gear
    By Tigra16V in forum Engine & Drivetrain
    Last Post: 13th September 2012, 15:33
  3. Auto gearbox
    By maud2450 in forum Engine & Drivetrain
    Last Post: 13th November 2011, 17:13
  4. auto gearbox
    By cerbrious in forum Engine & Drivetrain
    Last Post: 17th July 2009, 20:04
  5. Auto gearbox oil
    By pinnacare in forum Vectra C / Signum Car Chat
    Last Post: 26th November 2008, 16:44
