Thread: Squeaky and Stiff Gearstick???
    Regular Member ChrisFox's Avatar
    Feb 2007
    Northampton
    Default Squeaky and Stiff Gearstick???
    Over the last few months my gearstick has become a bit squeaky and stiff to move. It's not really bad, just a bit annoying
    Is there a quick fix or is there easy access?...I have a tin of grease, just need to know where to put it!!!
    Regular Member scoobs's Avatar
    Leicestershire in the sticks!
    Quote Originally Posted by ChrisFox View Post
    Take out the oddments tray under the heater controls, just pull firmly towards you. Then remove the ashtray and silver gaiter surround, you can then unclip the gaiter from the rear and pull it up revealing the gear linkage underneath. There's not a lot of room to get your hand in with grease, but a can of WD40 does the trick.
    Then as the saying goes..........refitting is the reversal of removal.
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Mileage : 137000
    Is the box notchy in 1st and second?
    Regular Member Kyser143's Avatar
    Bradford
    now you say that rushy mine is ....any fix for that lol
    Vehicle : 9-3 Wagon
    Mileage : 137000
    If you have a 5 speed F23 box there is. Its Field Remedy 1653. Repair Kit, Partno.: 9201451. Its a dealer job and expensive out of warranty. TBH its better to just live with it.
    Bradford
    Will stick with it then mate ..does it more when cold...otherwise its fine.
    Vehicle : 9-3 Wagon
    Mileage : 137000
    Quote Originally Posted by Kyser143 View Post
    Thats the exact description on the field remedy.
    Regular Member Craig1985's Avatar
    Dec 2007
    harwich essex
    confused
    Quote Originally Posted by rushy View Post
    mines like in in 1 n 2nd but have 07 facelift 6 speed? should i be worried?
    west yorkshire
    dont worry mate i just got a new box and its still like that
    Vehicle : 9-3 Wagon
    Mileage : 137000
    Quote Originally Posted by vectra1.9cdti View Post
    It only applies to the F23 5 speed mate. Are the gears hard to engage? Might just be a cable adjustment or the hydraulic clutch that needs bleeding.
  1. Stiff pedal on 2.2 dti
    By wads187 in forum Vectra C / Signum Troubleshooting
    Last Post: 7th May 2012, 20:53
  2. Stiff steering.
    By andy-j in forum Suspension, Wheels & Brakes
    Last Post: 12th December 2011, 20:07
  3. stiff gears
    By nicj in forum Engine & Drivetrain
    Last Post: 4th November 2011, 14:30
  4. Stiff gear changes
    By James7 in forum Engine & Drivetrain
    Last Post: 17th April 2007, 19:45
  5. Stiff gearchange
    By monkeybusiness in forum Engine & Drivetrain
    Last Post: 19th January 2007, 18:58
https:www.vectra-c.comforumshowthread.php37958-Squeaky-and-Stiff-Gearstick
Vectra c gears left squeeke
squeaky gearboxgearstick stuck in 1&2 when cold corsa dsqueaky clutch on insigniainsignia gearlever going stiffgearbox getting stiff squeekyvauxhall gearbox getting stiff squeakyfix squeaky gear changevauxhall insigna sqeeky gear squeaky gear sticksqueaking gearstick from 3rd to 4thgear stick squeaking vauxhallvauxhall astra squeaky gear sticksqueaky gear change vectrainsignia gearstick squeakingSqueak from gear stick on a vauxhall vectorvectra c gear stick stiffvauxhall corsa d squeaking gear stickhow to fix a squeaky gear stick on a vauxhall corsainsignia tight gear stickcorsa d squeaky Gear stick why does my gear stick squeak vectra cinsignia gear squeakvectra c squeaky gear stick
