Results 1 to 10 of 19
Thread: My Auto has developed a serious problem!
    Regular Member mushy2007's Avatar
    Liverpool
    Exclamation My Auto has developed a serious problem!
    Right Guys,
    Hopefully someone can help.
    On friday night on the way home from a meeting in bradford I was sat at a set of lights with my foot on the brake, then when the lights changed I went to go and the car kept kangerooing up the street
    No warning lights came on and the engine sounded normal, so i limped around the corner and turned the ignition off and then back on, guess what in ran fine
    Well even worse tonight I was doing 70mph on a dual lane carriage way when bang out of no where the car wouldnt engage gear so quickly changed to semi-auto and that wouldnt work either.
    Had to put my hazards on and pull into the first lane whilst cars swerved to avoid me, turned the car off and re-started and it worked!
    Does anyone have an idea on what this could be as the ecu doesnt pick up a fault and the engine runs normal.
    Regular Member j13hdb's Avatar
    Nottingham
    How's your rad water? If low look at previous links!
    Liverpool
    Quote Originally Posted by j13hdb View Post
    What links, do you mean threads?
    Hows is this linked?
    Liverpool
    Right,
    Just searched back over other threads and it looks like it could be the gearbox issue.
    The header tank has heavy green residue on the bottom and the coolant has gone from a nice pink to a greeny - pink colour.
    Is this the start of a gearbox failure?
    EVERYWHERE
    Yep,that sounds fairly ominous! Another gearbox failure on a tuned car! Is it still under warranty?
    Liverpool
    Yep, still got a year and a half left.
    Its only had the BSR for less than a month, but if thats the case I will certaintly want a refund from BSR!!!
    EVERYWHERE
    Well it's not really the fault of BSR because like so many other engine tuners they don't ask you whether or not your drivetrain can take the extra power and they certainly won't find out for you if it can or not!
    I'm not sure what auto gearbox is fitted to the 1.9 CDTI.It needs to be rated for at least 400Nm of torque with a tuning box fitted.
    Make sure you take the tuning box off when you limp it back to the stealers.
    Liverpool
    No its not the fault of BSR, however if their offering the tuning package with 412nm of torque and the gearbox cant take it, surely they shoud warn you.
    I'll take it in Monday morning and remove the map before.
    I'll keep the site up-todate on whats wrong.
    This is my second car thats now developed problems, my 54 reg 2.2 direct was plagued as well.
    Full Member GazVXLINE170's Avatar
    Jun 2007
    Scotland
    Vehicle : Insignia
    Trim : SRI VX-Line Nav
    Engine : 2.0 CDTI [170 PS]
    Year : 2015
    Mileage : 27000
    Quote Originally Posted by mushy2007 View Post
    I take it you're no gonna tell VX you fitted a tuning kit?LOL
    Hope you get it sorted.
    Gazza4
    Insignia VX-Line Nav CDTI 170.
    EVERYWHERE
    I think it could be this one,which is only rated at 280 ft/lbs (approx 375 Nm) torque capacity.
    http://www.worldcarfans.com/2050825....peed-automatic
  1. my signum has developed a leak
    By elite lee in forum Troubleshooting
    Last Post: 10th July 2011, 14:44
  2. 3.2 Auto Box Problem.. I think!!... Help!
    By VinnyPeewee in forum Engine & Drivetrain
    Last Post: 29th May 2009, 14:18
  3. Who has developed the Insignia diesel ?
    By baard in forum Insignia Chat (READ ONLY)
    Last Post: 5th March 2009, 00:03
  4. Dti Developed Horrible Rattle
    By craigbarlow18 in forum General Chat
    Last Post: 9th November 2008, 00:21
  5. Developed a squeak!
    By matth42 in forum Suspension, Wheels & Brakes
    Last Post: 13th February 2008, 14:38
