Page 1 of 4 123 ... LastLast
Results 1 to 10 of 35
Thread: Spring Sleeve Mod
    Regular Member deanos's Avatar
    UK
    Vehicle : Insignia
    Engine : 2.0
    Year : 2011
    Default Spring Sleeve Mod
    Ive suposedly had the front sleeve mod done by the dealers, but ive looked and cant see anything on the springs, is it obvious that its been done ?
    Anybody got any pics of the sleeves in place ?
    no pics, but you should be able to feel a plastic sleeve has been placed around the lower coil of the spring, where it sits into the spring pan....it's about 3mm thick and about 5" long
    UK
    Vehicle : Insignia
    Engine : 2.0
    Year : 2011
    Ive had a quick feel but couldnt feel anything, will have another look tomorrow.
    They changed the drop links which i paid (labour free) for and suposedly the spring sleeves for free under warranty, but heard another knock today
    thanks
    did they change the anti roll bar mount rubbers as well?....a common cause of knocks over speedbumps..
    UK
    Vehicle : Insignia
    Engine : 2.0
    Year : 2011
    No they didnt, the car was out of warranty in Nov but managed to get this done , it only made a knock when i had the wheel turned fully when coming onto my drive, its only done it once.
    right, that is classic 'spring mod' noise...perhaps they never put a smear of grease in the pans?..it helps the nylon 'mod' move better..
    UK
    Vehicle : Insignia
    Engine : 2.0
    Year : 2011
    Thanks m8 is there anything i could do to save me going back again
    yep, you could try shooting some spray grease into the bottom pan around the spring mod to lube it up a bit..
    UK
    Vehicle : Insignia
    Engine : 2.0
    Year : 2011
    Thanks will have a go tomorrow , will report back if i can find the sleeves, i presume i should be able to feel them .
    yep, you should be able to feel it...
  1. its the top strut sleeve right???
    By gsxrster in forum Vectra C / Signum Car Chat
    Last Post: 3rd April 2011, 20:25
  2. spring sleeve mod
    By delberto in forum Suspension, Wheels & Brakes
    Last Post: 19th March 2011, 01:36
vectra c forum spring sleve
