Results 1 to 10 of 11
Thread: Solid flywheel replacement for the DMF ??
    Regular Member DeanF's Avatar
    Nov 2007
    Staffordshire
    Default Solid flywheel replacement for the DMF ??
    Does anyone know if anybody supplies a solid flywheel/Clutch kit for the Vectra-c ??
    I know other companies supply such kits for the new Transit Etc, Which suffers with Dual Mass Flywheel issues.
    WOuld be great if you could just fit a solid flywheel & forget
    Dean
    never heard of one avaliable, but with the rate they fail at, it can't be long till they do start doing them....
    member of the smoke patrol 230bhp+
    ill take one of them
    Nov 2007
    Staffordshire
    Thats exactly what i was thinking, I mean what would it take to manufacture a solid flywheel with a clutch/pressure plate & Release bearing to suit.
    The new transits Dmf's are failing rapidly & you can now get the kit for £160 + Vat, Yes there are 100's of transits about , But there are also 100's of vectra's. Surely there is some good money to be made there by someone
    Dean
    yep, they only have to make a new flywheel to use with the standard clutch....maybe one of the major tuners will drop on to quite an open market..
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    Been on z22se looking into this and it seems it could be possible,use a lightened flywheel and clutch from a Vec B, then you need a spacer for the slave cylinder(to move it closer to the clutch),not much cheaper but more reliable!
    Nov 2007
    Staffordshire
    Quote Originally Posted by tyreman View Post
    You must of been reading my brain (Can be done quite quickly ) I was thinking last night if the Vectra B solid setup was similar to the Vec-c & could be adapted.
    Good bit of info there
    Do you have a link to your findings ??
    Dean
    Regular Member Vid's Avatar
    May 2007
    In the inventing shed...
    http://www.z22se.co.uk/forum/viewtop...=asc&&start=25
    Same principle I imagine to apply to Vec C box, I have been looking at a way around this as I want to fit a lightened flywheel!
    If someone gets more detail on this, share the wealth!!
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    That's one of the threads i was looking at,best to do a search for DMF or LIGHTENED FLYWHEEL.
    newcastle
    Has anyone tried using a solid flywheel and appropriate clutch kit, possibly using a different fluid pipe to the slave cylinder to get rid of this crazy unreliable dual mass flywheel.
  1. solid flywheel kit cdti 150
    By decks in forum Vectra C / Signum Car Chat
    Last Post: 23rd September 2012, 17:32
  2. thoughts on solid flywheel
    By chris1984 in forum Vectra C / Signum Car Chat
    Last Post: 8th August 2012, 07:36
  3. solid flywheel
    Last Post: 30th March 2012, 18:31
  4. solid conversion flywheel
    By abz123 in forum Engine & Drivetrain
    Last Post: 2nd March 2012, 21:43
  5. DMF vs Solid Flywheel
    By AKeeNShoT in forum Engine & Drivetrain
    Last Post: 1st October 2010, 10:22
