Thread: Alternator fault
    New Member RCP1's Avatar
    Sheffield
    Angry Alternator fault
    Hi,I'm new to the forum and need a bit of help and advice.
    Driving home and the alternator light came on, along with that spanner on the car light (technical I Know). Are both these problems related or seperate issues and is the car safe to drive down to the nearest vx dealer.
    Any advice would be welcome.
    Vectra 1.9 TDI, 52 plate
    same problem....
    it's safe to drive as long as the belt is still in place...just do it in full daylight as no charge may be getting into the battery...
    Be prepared for a reasonably big bill as the alternators aren't cheap at VX....
    Administrator plasma's Avatar
    On the Forum
    399 Post(s)
    Engine : 150
    Mileage : 74000
    What could be done is have an Independant garage remove your alternator and see if its the diode pack that has gone, this can be replaced by a alternator specilaist quite cheaply. Depends though if you can afford to have the car off the road for a few days though.. Just a thought..
    and a very good one...both the diode and the rectifier packs cost little, compared to an alternator replacement at VX...As the car is well out of warranty, use an independant garage and save big bucks.....
    if you have access to a multimeter, the terminals should produce a reading of 12v without the engine running and around 13.8- 14.5v with it running if the alternator is healty..
    Sheffield
    Default alternator
    Thanks for that info, just been looking through extended warranty I took out and hopefully alternator is covered.
    My concerns are that when I lifted the bonnet to have a butchers, water level was very high and engine seemed to be sucking in air. Gonna ring warranty people before I book it in with vx.
  1. Display fault after new alternator
    By Chris-o in forum Electrical & ICE (including SatNav)
    Last Post: 29th January 2012, 23:58
  2. fault code for alternator problems
    By mace in forum Vectra C / Signum Troubleshooting
    Last Post: 24th January 2011, 21:46
  3. poss alternator fault??
    By signumturbo04 in forum Vectra C / Signum Car Chat
    Last Post: 8th December 2010, 12:23
  4. P1109 fault code after alternator replacment
    By knfruitbat in forum Vectra C / Signum Troubleshooting
    Last Post: 19th November 2010, 21:05
  5. Alternator causing DPF fault?
    By Andiman in forum Vectra C / Signum Car Chat
    Last Post: 4th October 2009, 18:34
